Ok, I got a banshee that wouldn’t start.
what I have done since: cleaned carbs completely, adjusting floats, adjusted carb screws to stock, removed old fuel and blew out fuel lines, checked/cleaned reeds, changed spark plugs, compression tested 125psi each side. It will start only with the help of starting fluid, no idle, misfires from right cylinder.
It came with a cool head, fmf pipes and what looks to be a tors delete carb setup installed. Also received box of miscellaneous old parts including cdi box and stator...I’m guessing previous owner had some kind of issue with this.
attached is video of bike running and missing ANY help would be great! I will switch plug wires to see if mis goes to other cylinder and check to see if the brain was disconnected. Any other thoughts?
I guess the video is larger than 0.5kb. Will try to reduce size and post that
