Coester
Everything posted by Coester
  1. How and where do you plan to ride? The J arms are fine with a good bearing kit installed. No need for an A arm chassis. The steering geometry is the same. On the other hand, there are some that prefer the J arm chassis. You might be able to trade ? Cheers!
  2. If you don’t want to risk using JB weld or other repair material, why not look for a used OEM carb or pair on ebay or Craigslist? Might get lucky and find a set that has the idle screws already done?
  3. Hello. I know this is a very old post but was wondering if bumper still available? Please advise. Thanks
  4. Wow. I thought this was a Banshee forum ?
  5. Go to any of the OEM parts suppliers and look up the number for your particular year and item. You may in fact find what your looking for. Also, Tito’s carries many OEM plastics with numerous color choices. Good luck and ride safely.
  6. Check out BDT racing for all your ATC and TRX needs. He makes the billet pegs you’re looking for.
  7. The Fuel/oil mix ratio will also affect your jetting. More oil in the fuel, the leaner the air/fuel ratio is going to be and vice versa. Less oil, richer air/fuel ratio.
  8. kawa110 The RZ’s were only sold in the U.S. in 1984 and 1985. They were great bikes. However, that was 35 years ago. The bikes and parts are getting very rare today. Changing the sprockets will affect your final drive ratio only. Doing that will make 0 effect on the internal gear ratios and the spacing between each gear selected. Theres more to it than closer 4-5-6th. 1-2-3 are spaced farther apart than Banshee 1-2-3. For some, this is also of benefit. There is a guy in Europe that builds gear sets for RZ’s that will work in Banshees too. They are VERY pricey though... Is it worth it? Probably not to the average Banshee enthusiast, but we all know how much time and effort some put into their toys. For others, it’s only money... Cheers!
  9. There seems to be a consensus that if an RZ transmission is installed, the machine will have much taller gearing. And beyond that, altering the drive sprockets will be necessary to make it work. That is in correct. Also, you cannot interchange seperate gears to build “custom” ratios. Like most constant mesh transmissions, every gear must be used with it’s corresponding gear. The final overall gearing between the two transmissions is very close. External gearing changes wouldn’t be required or necessary. The beauty of the RZ transmission is it’s noticeably closer 4,5, and 6th ratio which many riders like. Most Banshees will drop out of the powerband when shifting from 5th to 6th when on a hill, against a head wind, riding in the dunes or externally geared for hi speed because the gear ratio change from 5th to 6th is 16.26%, very similar to every other gear change. The RZ transmission will rectify those issues. The jump between 5th and 6th with RZ transmission is 7.6%. Significantly closer. And, the jump from 4th to 5th on the Banshee is also wider at 16.4% vs the RZ’s closer 11.2%. I was lucky enough to test the differences many moons ago when Banshees were first available and was making my living racing them professionally. For a couple of years I was a Team Yamaha ATV racer and part of the team that beat the competition in the 1986 Baja 1000 to debut the New machine for 1987. It’s too bad the RZ gears sets are no longer available. They were an admirable alteration for many. Cheers!
  10. I can see most of the posts in this thread are VERY old, but most everything posted on here is incorrect. Hopefully everyone figured out what was true and have a better understanding of the RZ and Banshee transmissions, their interchangeability and reality’s of running the RZ vs Banshee tranny.
