jnormie917
Everything posted by jnormie917
  1. I bought a banshee that I'm rebuilding and I noticed that the pin for sixth gear has been shaved/ground off of the shift star. Other than that it appears to be a completely stock shift star(its steel not billet and the lobes aren't rounded off). For some reason I didn't notice the shift star until now, so the cases are already together. I didn't notice anything out of the ordinary with the shift drum and gears, but I didn't think to compare them to an OEM. From what I've found so far most override tranny mods have the channels in the drum machined wider in certain spots, and there wasn't any of that on my drum. I am able to turn the star with pliers and put in sixth, so that makes me think that its a stock drum, but I don't have any experience with tranny mods so I could be wrong. I'm wondering if it would be possible to weld a pin or drill and tap a hole or something to add the sixth gear pin back onto the star, or if it would be better to just buy a new one.
  2. Thanks, definitely will look into that one. So if I get a billet basket, do I need to upgrade the pressure plate as well or do the stock ones work ok?
  3. Yeah, mine's got the stock basket with the rivets on the back... Looking a bit closer it looks like it had been run on the bad cushions for a while since there's some pretty severe deformation of the basket/hub where the plates were slamming into them. Anyone know of a good kit that has a basket hub and plates, or will I need to get them separately? I was thinking of going with Tusk competition plates and hd springs from Rocky Mountain ATV, but if I could get everything in a set I'd probably do that.
  4. So yesterday I bought a 2003 Banshee on OfferUp for a steal. The guy bought it from his brother in law who built it and from the looks of it put several thousand into it. After using it only a handful of times, he got too busy and it sat in his garage for 2-3 years. It's got a Coolhead, full Toomey T5 exhaust, extended swingarm, custom billet clutch and stator covers, hot rods, ported cylinders, extended radiator, adjustable billet stator plate, and a few other things I think. It's been bored somewhere in the neighborhood of 2.5mm over stock as near as I can tell, I haven't been able to measure it with calipers or a bore gauge yet. So the sad part is that from the looks of it last time it was taken apart/rebuilt, it got slapped back together in a hurry. There's gasket maker on pretty much every seam where there should have been a proper gasket (heads, clutch cover, between the cases, and all over the boots on the reed cages). I have the engine completely disassembled and cases split as of right now. When taking out the clutch, I noticed there is a pretty good amount of play between the clutch basket and the gear on it, which from what I've read indicates bad cushions. I'm putting together a list of everything I need to buy to get it running, but I want to save as much as I can where possible. Right now my question is how bad is it to run on bad clutch cushions? Will it lead to further damage down the road or affect performance?
