JSBanshee
Everything posted by JSBanshee
  1. Thank y’all for the help
  2. And to check if I burn any pistons, would I know by checking cylinder compression? Because I checked them and each one has 160 with 21cc domes
  3. How would silicon work around the leak ?
  4. If it’s one of those two, would I have to slit the motor?
  5. I just checked for any air leak and I have a big one it won’t even hold air, you can actually hear it come out as I’m pumping, sounds like it’s coming out by the flywheel, any suggestions on where it might be coming out?
  6. I don’t try to pop the clutch
  7. How do I find him
  8. Around what is the jetting suppose to be my elevation is 157 ft
  9. It has street tires at the moment, I think it has stock gearing, +4 swing arm, I’m not quiet sure of the jetting, it has shearer inframe small bore pipes, heavy duty clutch lock out clutch , trx is stock
  10. I have a cheetah cub but it lags on the throttle when launching. A trx 450 beats it from launch, is that normal or is it the jets ? it’s a cheetah cub 4 mil Vito welded crank with 35mm carbs
