Bobbybrown2018
Everything posted by Bobbybrown2018
  1. It's been cut for a 4mil
  2. I am building my 4 mil banshee stock cylinders that have been ported pj34mm carbs spacer plates on the carbs on a stock head on race fuel what would be a good starting jetting for breaking in my motor elevation 1086
  3. Yes I need domes cut for a 4mil stroker but I want to run pump fuel
  4. Who can I buy 4mil domes for a stealth head from to run pump fuel
  5. Can u send me a picture of an example
  6. After I get my cylinders ported do I need to port my pistons
  7. Exhaust is 30mm from the top of jug and the intake is 67.5 mm to the top of the jug
  8. I had it ported I was told it was for a 4mil but he person the ported them said that i needed spacer plates how can i tell if i need to re port them or what i need to do
  9. I am new to building Stroker motors I'm doing a 4 mil stroker motor and I have been told both ways that the spacer plate is the best way and that redoming the heads is the best way to go can you guys explain why with one is better that would be great
  10. Reed spacers sorry
  11. I blew up my banshee so I decided to buy new jugs and have them ported because my jugs were at 66.25 I have them ported on the high end of trail porting I have t5 pipes khien pj34mm carbs elevation is 1085 with spacer plates and +4 timing what's a good jet to start with the khiens
  12. What can I do get some more power
  13. I was told it was in between a trail and a drag port I am running pj34 carb
  14. They are ported
  15. Currently it's my trail bike but I got out ran by my friends built raptor so I. Trying to squeeze some more power out of it it's a 4 mil with OEM ported cylinders I have a pump gas head in it now but I had a OEM head cut for alky but idk what I need for the carbs to make them run alky
  16. What do I need to get done to my 4 mil banshee to run methonal
  17. I'm doing a 4 mil stroker kit on my banshee and I have a set of ported cylinders that are bored to 65mm is there any where I can get a set of blaster style pistons under 66mm I dont want to bore my cylinders that much if I can help it
  18. I'm doing a 4 mil stroker kit on my banshee and I have a set of ported cylinders that are bored to 65mm is there any where I can get a set of blaster style pistons under 66mm I dont want to bore my cylinders that much if I can help it
  19. What is the best way to sync my carbs air fuel mixture
  20. Ok cool u will
  21. Im looking to do a 4 mil on my banshee and I want to know what us the best kit to go with and why
  22. My rear shock is fine it's just my right front shock is locking up and wont decompress
