Glenn
Everything posted by Glenn
  1. I looked Gary's name up on Facebook but don't know witch one is the right one. Need to get a hold of him about a stator. Any suggestions would be great.
  2. Yeah this stator I ordered new is junk.
  3. Thank you
  4. What company do you guys recommend for a new stator?
  5. Ok the lighting coil is .1 to .2 witch is below spec. The pickup coil is 128 witch is in the ball park. The ignition coil is 12.8 which is below spec so I guess I got a brand new piece of junk....LOL
  6. Just walked out to the barn. I am gonna check them now and will post the results in just a bit. It would definitely make more sense to me if the new stator didn't check out
  7. I just put them on yesterday. I am gonna go out there now and test them with the ohm meter just to make sure the new parts are good to go.
  8. if you want to throw parts at it replace the CDI, then the coil, then the stator, then the wiring harness.... when it still doesn't run come back and follow directions.... Quote If you would read my very first post you would see I have already put a new stator and coil on the bike. The stator tested bad the coil had 1 bad wire so it also got replaced. I was asking if I check the stuff the guy listed above in order and everything checks out is it safe to say the CDI BOX is bad?
  9. Is there a way to check the CDI or just check everything else you listed and if all that checks out then just replace the CDI BOX?
  10. I put a new stator and coil on the bike and still have no spark at the plugs. If you turn the lights on and kick it fast the headlights try to light up but I still have no spark at the plugs and I'm using a thing between the plug wire and plug to show if you have spark. If the headlights are getting power shouldn't I be getting power to the plugs also? Or does the power for the coil have to go threw the CDI BOX before it sends it to the coil for the spark?
