if you want to throw parts at it replace the CDI,
then the coil,
then the stator,
then the wiring harness....
when it still doesn't run come back and follow directions....
Quote
If you would read my very first post you would see I have already put a new stator and coil on the bike. The stator tested bad the coil had 1 bad wire so it also got replaced. I was asking if I check the stuff the guy listed above in order and everything checks out is it safe to say the CDI BOX is bad?
