BansheeBird
Everything posted by BansheeBird
  1. What do yall recommend for size of domes? I am 1500ft above sea level. I have a banshee that has full fmf, dune ported, boysen reeds, hot rod crank, k&n air filters. I was thiking 18cc but of course i would run 110 octane
  2. will my setup run with ported and polished, 20cc domes, fmf powercore 2 pipes on pump gas? i dont want to run it too hot. and if it does run then will i have to change my gas mix ratio
  3. the only reason im looking into new cdi is because my oem is fried. ill have the cdi set at oem power curve but what is the best set up for me to get good performance but having a reliable build?
  4. jokes on you i already rebuilt it lol but thats only cuz the guy i bought it from didnt know how to run the damn thing. I appreciate al the help. I am still learning about the higher performance work and how to make everything run good and right with domes, pipes, carbs...
  5. Can you run a dyna cdi without programming it? If i were to throw a dyna cdi on my banshee without hooking it up to a computer to program will it run?
  6. Can you run a dynatek cdi without programming? Is it plug and play?
  7. Does an aftermarket coil or regulator make a difference in power on a banshee?
  8. Does an aftermarket regulator really make a difference?
  9. thank you. do you know how many turns out the air and screw needs?
  10. Ok so i have a 1997 yamaha banshee and im looking to make a bad bitch of it. So I plan on doing 20cc domes, 34mm carb, advanced timing, dyna cdi, full fmf powercore 2 exhaust. So what I am wondering is with all this should i run 110 octane? also do i have to program the dyna before i put it on and go riding? and what are the specs for the air/ idle adjustment on the 34mm carbs for 70 degree weather?
  11. Ok so i have a 1997 yamaha banshee and im looking to make a bad bitch of it. So I plan on doing 20cc domes, 34mm carb, advanced timing, dyna cdi, full fmf powercore 2 exhaust. So what I am wondering is with all this should i run 110 octane? also do i have to program the dyna before i put it on and go riding? and what are the specs for the air/ idle adjustment on the 34mm carbs for 70 degree weather?
  12. Ok so i have a 1997 yamaha banshee and im looking to make a bad bitch of it. So I plan on doing 20cc domes, 34mm carb, advanced timing, dyna cdi, full fmf powercore 2 exhaust. So what I am wondering is with all this should i run 110 octane? also do i have to program the dyna before i put it on and go riding? and what are the specs for the air/ idle adjustment on the 34mm carbs for 70 degree weather?
