Clueless87JFrame
Everything posted by Clueless87JFrame
Thanks man and will do. Yeah I woulda never bought this thing if I didn't think I could have handled the rebuild somewhat easily. I always spend the extra time or money on a motor to replace everything that way it's ready to roll but I may have made a mistake with not lapping the cylinders or head from the start Sent from my iPhone using Tapatalk
Yeah I was leaning towards the top of that cylinder being partially warped or the head. The only step I didn't take was lapping the head and cylinder before I put it together. Everything was torqued exactly like the manual said. Yeah I figured it was a metal-metal seal and the oring was just for insurance and to keep water out but man it's hard to imagine it ever would seal right with the jugs being separately bolted down and the head being one piece covering both jugs. Sent from my iPhone using Tapatalk
Idk how long aluminum will last but you can give it a try. Most of the ones I've seen were teflon type material pressed in. I used bearing brass because I've got about a thousand lbs of it laying beside the lathe Sent from my iPhone using Tapatalk
- 7 replies
- 1
- bushings
- suspension
(and 1 more)
Tagged with:
But the ones I took out were the high temp style red orings. New ones I received were black and I asked the fella about it and he said "well we use to use red but the black work just as good"........ now here we sit with a f'ed up brand new piston that left pecker tracks on my freshly bored/honed/ported cylinder 15 min later. Fml Sent from my iPhone using Tapatalk
I was turning it pretty good when I heard the pop/spew sound it made when that oring let go. Engine quickly coasted back down to nothing and died. Would not start back. But the weird thing was - when I disassembled the engine the first go round - both orings around the cylinder domes were in perfect shape Sent from my iPhone using Tapatalk
Well I guess what I meant was - since I was already rebuilding it - I bought all new seals and gaskets, like I would normally do on a rebuilt. I don't reuse seals - ever. I just didn't imagine it would be a seal since there isn't any signs of fuel/oil leaking anywhere around any of the seals on the motor after looking closely at it right after she popped. Sent from my iPhone using Tapatalk
Oh if that's all there is to it - I'll order them from whoever on here or eBay has them. Just didn't want to get the run around on some little aluminum domes and also didn't want to wait a month to get parts back if all that needed to be done was a little degree change. I need some for the 66.5 mm bore too. Didn't know how hard that was to come by. But either way this dang thing is about to get on my nerves already. Just want to get it running longer than 15 min hahaha Sent from my iPhone using Tapatalk
92 model - get on boats.net and order what you need. You can usually get away with ball honing those cast cylinders and slapping some pro-marine pistons back in, bearings (if needed) seals and some Loctite anaerobic gasket maker and torque everything back. One piece cranks so it's much easier. If I was going to guess I'd say $1000 or less Sent from my iPhone using Tapatalk
Yeah those are easier for me because I've been running and playing with them for 25 years haha. My first banshee and so far it's been a little nightmare. Yeah it was ported when I got it - then ports cleaned up again a few weeks ago before I rebuilt it. I'll measure it and see what I come up with. I left the jetting the same in the 34mm carbs since we didn't really change much just cleaned it up and rebuilt it. Sent from my iPhone using Tapatalk
So with those pistons - which cool head would be the best to buy ? Which domes? And as far as ports - I was told they were ready to roll so that's why I put her back together. The port in the photo doesn't look good because it has aluminum growing on it. They looked great before I put it together - and the other sleeve/ports look fine. No scoring or compression loss whatsoever Sent from my iPhone using Tapatalk
Exactly why I asked yalls opinions haha - I knew I had something messed up. Outboards are much easier. Less porting - and easier to fix usually. This was my first go round and I'm still learning. $4-500 mistake but hey - at least there isn't a rod hanging out........yet Sent from my iPhone using Tapatalk
