La_Madre_Tuya
Recent Profile Visitors
378 profile views
La_Madre_Tuya's Achievements
  1. Finally got around to opening the water pump cover yesterday... the gasket was definitely the issue, the screws holding the plate inside were completely loose [emoji29][emoji29]
  2. Yea I'll have to check it out better when I get a chance. But yes it was the right side tie rod that broke and the leak definitely was a result of the accident Sent from my SM-N910V using Tapatalk
  3. What's up everyone. So I took a spill about a month or so ago on my shee out in the street. Nothing too serious, or at least I thought. Broke a tie rod which is all I thought happened but yesterday I went to wrench on her a bit and went to check my coolant level since I noticed some spilled out in the accident and as I opened the cap it started leaking like crazy under the motor. Looks to be from the water/coolant pump but directly underneath? Seems like at the seal. Anyone have a clue what it might be? Haven't cracked it open to see inside yet Sent from my SM-N910V using Tapatalk
  4. Nicee, I'm going to look into those. Thanks for the info Sent from my SM-N910V using Tapatalk
  5. ..... Thanks a ton Sent from my SM-N910V using Tapatalk
  6. What's up guys, fairly new to banshees but have had mine for a few months now. Broke a tie rod not too long ago so I've been trying to find a good set to upgrade to. Measured my a arms and assume they're +2 since I'm measuring 14 1/4 I believe. Wanted to see what brand you guys recommend going with. Thank you guys -Mike
