Brokeshee
Everything posted by Brokeshee
  1. Where did you buy your covers for your front lights..i want them! Sent from my SM-A310Y using Tapatalk
  2. Pics of your banshees? Sent from my SM-A310Y using Tapatalk
  3. Went out for a ride got cops called on me..whats the size of the front sprocket bolt? Sent from my SM-A310Y using Tapatalk
  4. Il try get some silicone hose or something anything I got I feeling I might not hit the power band as hard Sent from my SM-A310Y using Tapatalk
  5. So I'm waiting for some clamps but I want to go riding tomorrow. What's worst thing that can happen from running with no exclamps? Obviously smoke is going to come out where the pipes connect but is there even a reason to run exhaust clamps?? Sent from my SM-A310Y using Tapatalk
  6. That's what I was thinking too i guess il try figure out something to do the job until I get new pipes. Cheers Sent from my SM-A310Y using Tapatalk
  7. This is the peice here Sent from my SM-A310Y using Tapatalk
  8. The silencer itself..the bolt goes through it and it has rubber..I'm not sure if actually apart of the silencer itself but mine has come off from riding to hard I guess Sent from my SM-A310Y using Tapatalk
  9. Where can you buy the rubber peice that the bolt goes through to mount the silencer to the frame? Sent from my SM-A310Y using Tapatalk
  10. I'm definitely not perfect, however im young compared to Tyler so i might say stupid things sometimes.. When I joined hq but it's pretty safe to say I took more shit then most and all I did was take it in good humor..most wouldn't of.. I can't even remember you? If I offended you with being retarded I apologize. Sent from my SM-A310Y using Tapatalk
  11. No problem have fun jetting the bitch [emoji482] Sent from my SM-A310Y using Tapatalk
  12. You adjust the carbs accordingly to your modifactions. Depending on your mods I'd start with mains an needle position, but you try get your all your jets dialed in in no particular order. Sent from my SM-A310Y using Tapatalk
  13. No problem. Glws Sent from my SM-A310Y using Tapatalk
  14. And how much for the lights Sent from my SM-A310Y using Tapatalk
  15. 1000 for pegs, axle, full bores an wheels? Sent from my SM-A310Y using Tapatalk
  16. 800 for fullbores an beadlock wheels? Shipping is expensive for me? Sent from my SM-A310Y using Tapatalk
  17. As far as the porting im not sure but there definitely ported. Stock needle..was thinking about geting 320 mains up to 350. I've had it for years IL plug chop when im back at home.. It could be running a lil lean so I'm going to up the mains now cause it's winter it could be why cause I never noticed it before. Sent from my SM-A310Y using Tapatalk
  18. Can u make some gold fenders Sent from my SM-A310Y using Tapatalk
  19. No to the plug chop will do one before I take it out next. Do you think what im experiencing could be due to too small main jets? Sent from my SM-A310Y using Tapatalk
  20. Last week when i went out ridingI noticed when I was full throttle in 6th gear if i let go of the throttle just a bit it feels like I'm pulling a lil more then if i was full throttle? I think I have 300 mains in there an riding at the beach pc piped knn filter lil porting..was thinking if I upped the mains I'd get the full pull at full throttle or is that just how it is with these tings Sent from my SM-A310Y using Tapatalk
  21. So your good? [emoji28][emoji482] Sent from my SM-A310Y using Tapatalk
  22. You should of left it to the professionals like me. Did you leak down test the motor after you built it? If not stop trying to start it an leak down test it Sent from my SM-A310Y using Tapatalk
  23. Just realized you might of built this motor? Being your first time m8 wouldn't be surprised if there's a air leak somewhere.. Sent from my SM-A310Y using Tapatalk
  24. If that doesn't get you going like hop said probably leaking somewhere so leak down test the bitch if what I said dont work Sent from my SM-A310Y using Tapatalk
  25. I'd pull ur carbs clean them check all your jets proper definitely up your mains..make sure your carbs are synced enough an can see both ping Mark's in the windows..adjust your idle screws an you should be good to go..choke it couple kicks with key off flick it on an your away m8 Sent from my SM-A310Y using Tapatalk
