Prescottguy89
Everything posted by Prescottguy89
  1. FIXED. Flywheel was so Rusty and wire was burned from the pipe
  2. Spark comes and goes?
  3. Foot hurts from kicking to mucch
    1. hoppedupandcutdown
      hoppedupandcutdown
      wear boots and stay hydrated
  4. Went riding left cylinder stopped running now neither will run compression is 120psi at 5000ft
  5. Arizona
  6. 1) What type of aftermarket exhaust do you have? Tommey t5 2) What type of airfilter do you have? uni no outter wear 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all No box 4) What is your elevation? 5000 ft 5) What size pilot jets are you using? 40 6) What size main jets are you using? 310 7) What temperature is your Banshee jetted for? 75 8) Do you have a port job? Full drag port 9) What kind of carbs? stock 10) What size carbs? Stock
  7. Need new silencers if you have a set for sell
  8. I have a square plug 2gu-50 coming it should work right same plugs. My coil says 2gu-50 so I just guessed on the right one
  9. Lol no c4
  10. I have a 89 banshee with aftermarket cdi but I'm buying a oem witch one is for mine 2gu-50s or 2gu-51????
  11. No dents finish is still pretty good switched to t5s trying to figure out how to put pics of them up
  12. Need both for a 1989 j arm anyone got one for sale??
  13. Not sure what's there worth let me know if interested
  14. I have a set of fmf fattys and another set of pipes but no silencers for sale
  15. Looking for a oem stator for a 89 2gu and a cdi plus t5 silencers
  16. Doing a 4mm kit right now and Yamaha wants 400 something bucks might have to spend the extr I guess. Could that even be the issue if the bike still runs
  17. Junk is what I find ehhh my local shop keeps trying to get me a Ricky stator they say there good. Is there any other then oem
  18. Ever sinceI got aftermarket stair and cdi it seems like bike runs funny? Don't seem like has as much pep and have to have the timing at plus 12 or its worst any clues??
