jrevans2571
Everything posted by jrevans2571
  1. Not sure what to make of it other than its Cooper in color and was around the rod area. When I got both cylinders off I tried turning motor over by hand and still wouldn't move but when I moved lever back and forth it would move positions but pistons wouldn't move. I went thru gears and it goes thru them just fine, or what appears to be fine. Inside of cylinders are scarred so obviously they need honed. Pistons are scarred so obviously bigger pistons. I'm just trying to understand what copper type substance that is. And what would be the next thing to look for? Sent from my SM-N910V using Tapatalk
  2. Yeah I'm a bit slow but I'm at this point now. I took cylinders off and found this Sent from my SM-N910V using Tapatalk
  3. Would anyone please like to tell me what happened? And what my ignorance got myself into? Sent from my SM-N910V using Tapatalk
  4. Just fuckin cried? If that's what that means I'm with ya buddy Sent from my SM-N910V using Tapatalk
  5. Huh? Sent from my SM-N910V using Tapatalk
  6. Good news, cutting wire did the trick. Cut it, kicked it over gave it gas, and it began to Rev up! Bad news.... After about 5 seconds it died out.... Went to start it up again and we'll, motor is locked up... Story of my life fellas. I seem to move too fast or too slow. Not sure what to do at this point. I don't have alot into it right now but I'm not sure if it's worth the headache. Hell, I don't even know if it's pistons, crank. Don't even know of where to begin to look Sent from my SM-N910V using Tapatalk
  7. Well I got good news and bad news Sent from my SM-N910V using Tapatalk
  8. No not yet. I'm at work just racking my brain wanting every arsenal available for when I get off. I do that and report back around 5 central time Sent from my SM-N910V using Tapatalk
  9. It seems like something is not allowing not to rev Sent from my SM-N910V using Tapatalk
  10. What else could possibly make it run this way? Sent from my SM-N910V using Tapatalk
  11. Tors elem kit installed so yes Sent from my SM-N910V using Tapatalk
  12. If it doesn't? Sent from my SM-N910V using Tapatalk
  13. What would I be checking exactly? Sent from my SM-N910V using Tapatalk
  14. Let me know if you got email Sent from my SM-N910V using Tapatalk
  15. You have an email I can send you the video of how it's running? Sent from my SM-N910V using Tapatalk
  16. I put new ignition coil in so both plugs are getting spark. They both are getting warm. I'd still say right more so than left but definitely both Sent from my SM-N910V using Tapatalk
  17. What would mine have? Sent from my SM-N910V using Tapatalk
  18. Wouldn't let me load the video Sent from my SM-N910V using Tapatalk
  19. Question.... Still "on the job training" so, the banshee still isn't reving. Took a video of it and let someone see it who is a banshee owner. They are quite sure it's the parking brake that it is making it do this. I'm not sure what I am looking for here. I know the wire is not there where the clutch is. It's like someone took it out (last owner maybe). I'm not sure where to trace to look where it would of went? I looked at some old post and some said to cut wires at the harness at the cdi box? Any help would be great. Thanks Sent from my SM-N910V using Tapatalk
  20. How do you check the caps with the meter? And trim the ends? Sent from my SM-N910V using Tapatalk
  21. No it will run on either side. It's the one particular plug wire that it dies out on when you pull it,ir leave it on I should say. There is only one plug wire keeping bike going. But both wires seem to be getting fire because they seem to shock the shit out of me when I'm trying to pull them while the bike is running. It's weird. Only one will keep it running but both have fire going to them... What does that mean? Sent from my SM-N910V using Tapatalk
  22. I'm only firing on one cylinder. Bike won't Rev. When it's idling I can pull plugs and it will run with right but when I pull left it dies. When I switch them it does it with same plug. Does this mean the ignition is bad? Or cdi box? Or both? Or neither? I'm still learning so can someone please help me? Thanks Sent from my SM-N910V using Tapatalk
  23. What type of meter you use? Volt meter? Sent from my SM-N910V using Tapatalk
  24. Any way to check to see if it is the cap? B4 I go buy some? Sent from my SM-N910V using Tapatalk
