zachwells229x
Everything posted by zachwells229x
  1. Is it over heating? You probably just over filled the radiator? Sent from my Z812 using Tapatalk
  2. Hi I have an 02 shee with Tors delete kit and basic mods cool heads pipes reeds blah blah blah, I have no spark I had the coil bench tested and it came back with .4 ohms.... .02 higher than normal? I'm about to give up on the thing any help??? Sent from my Z812 using Tapatalk
  3. Would a higher reading mean there an issue or a lower reading? Sent from my Z812 using Tapatalk
  4. What would determine a bad coil too high or too low of a reading ? Sent from my Z812 using Tapatalk
  5. I'm getting .4 ohms from my coil .02 higher than normal? Is this a problem or could it simply be a slight variation in the testing equipment Sent from my Z812 using Tapatalk
  6. Can anybody help me I just joined this site today, I have an 02 shee with no spark stator is good and pick up is gapped correctly my ignition and run switch were tested and also said to be fine now the only thing u can think of is the coil or the cdi but there's no way to test a cdi only the coil ... Any help guys?? Sent from my Z812 using Tapatalk
