Kleinki
Everything posted by Kleinki
  1. Insolation covers..... The racing we do in south africa has loads of long grass and thorn bushes....
  2. Shes all good again.... Thats what happens when you run a topend for 10 years without changing.... Oops.....
  3. I was busy warming up before a race when this happened.... Happy it did not happen at wot [emoji85][emoji85][emoji85][emoji85][emoji85]
  4. Bending the little tube would of sorted that problem i guess.... Loads of ktm rides have the same problem mostly fuel splashing around the bowl and running out so they block it off but dont wane do that... Just happy its working now..
  5. 35mm keihin carb... It was pooring out like if the needle was stuck.
  6. So i set the floats again today bent the little pipe upwards and shes not leaking.... Lets hope it stays like that.
  7. I was reading that because the carb is sitting with a slight angle on the single intake, blokes are bending the tip of the copper tube a bit upwards to counter the angle. Any comments on that.. I dont wane block it off all he way like some riders scared of flooding the bike like crazy...
  8. Al of that is brand new im still on my first tank of fuel with the new parts....
  9. Just to clarify... Even when she is off the petrol runs so it cant be the vent tubes.... Is there anything else that can go wrong that will make the fuel run out..
  10. Brand new keihin 35mm carb... The problem i have is if shes running all is good but as soon as i stop and just idles fuel starts poring out of the overflow pipe. I did set the float lever... I even went a bit to much so she starves on topend but the fuel still comes out when she stops.... Any help please could it be the vent pipes...
  11. The left exhaust where the 2 joins together, there is a bit of a leak there...
  12. All is sealed... Doing compression test next week just waiting for my pressure tester to me fixed... There is no bogging or hesitation through the throttle range.... Plugs look good 2.... 3 kicks after she was assembled.... Really happy with how she runs... Did a gps speed test and get 120km/h on stock sprockets and 22's at the rear....
  13. Sorry final jetting.... And yes lid off no porting.... Domes 22cc.....
  14. Chariot 2-1 35mm keihin carb Main: 188 Pilot: 48 Air screw: 2 turns out Needle: EEK Needle clip: 3 Altitude: 6000ft Fuel mix: 32:1 maxima Mods on bike: Cool head. DMC 916 Exhaust. Fox Evol shocks. Racing radiator. Race hoses. Billet impeller. Beadlock rims. Shift star. Shift pro. Chariot 2:1 setup. Vforce4. 35mm keihin single airstriker carb. Clark 5.4 gallon tank. +2 stem. Yfz a arms. Braided hoses front. Hydraulic clutch. Flex handlebars. Dual throttle. Front tire blocks. Deadman's switch. Pro flow filter. DWT mud plugs.
  15. Cool head. DMC 916 Exhaust. Fox Evol shocks. Racing radiator. Race hoses. Billet impeller. Beadlock rims. Shift star. Shift pro. Chariot 2:1 setup. Vforce4. 35mm keihin single airstriker carb. Clark 5.4 gallon tank. +2 stem. Yfz a arms. Braided hoses front. Hydraulic clutch. Flex handlebars. Dual throttle. Front tire blocks. Deadman's switch. Pro flow filter. DWT mud plugs.
  16. Sorry tried to delete or move it but was to late...
  17. https://vimeo.com/164054644 https://vimeo.com/164054661
  18. Will fit the clark tank tomoro and new beadlock rims... Also got a new graphics kit going on will post pics when all is complete.... Can only test her next weekend... Hope everything will work properly [emoji33][emoji33][emoji33]
  19. So finally after 5 months out at sea im back home to play around with the arms and shocks and man it looks awesome...48" wide and sit perfect.
