SplitSide
Everything posted by SplitSide
  1. Got my chariot throttle looks brand new thank
  2. Looking for a set of shearer bb out the same side left or right side. Thanks
  3. Running 12 paddles extremes
  4. It's runs on vp 110 and Matt said he didn't touch the carbs k&t set them up and talked to them and he said that's the way he sets those carbs up at 5000ft in Utah
  5. Yeah Matt said to run 14/43 and running 110 fuel. What do you think with the needle it's the leanest one 6fj41
  6. It's a buddies quad Matt shearer was the last one to work on it. We did a leak down test last night was good. Ya that's what we thought the pilot jet was pretty high has a build sheet on it I'll see if I can find the fourm page and post it thanks for your help
  7. Have 421 cub have trouble launching falls on it face when you drop the clutch out of the hole. Has 145 compression timing +6 drag port gearing is 15/42 41mm flat side mikuni carbs shearer oof pipes 65 pilot jets 260 main 6fj41 needle 2600 elevation in Canada
  8. Pm sent for radiator
  9. You can get peps for a no link set up
  10. What's everybody running for a rear shock with a no link swing arm. Other than a Marvin shaw thanks
  11. Ok thanks
  12. I there was wondering if they are any good never really heard anything about them. Just seeing if they were made for a certain build thanks
  13. Can you run that with a no link swing arm
  14. You still have this motor and if you do does it have straight cut gears thanks
  15. Is the stator oem
  16. Hi there just seeing what size of tire you guys use for the wheelie bar for sand drags thanks
  17. Ok thanks for all of your help
  18. Is there any spots you don't want sand blast or is everything ok thanks
  19. Hi there just wondering if it's ok to sand blast your engine cases thanks
