threequarterthrottle
Everything posted by threequarterthrottle
newbie intro, dummy questions
threequarterthrottle replied to threequarterthrottle's topic in Banshee Repairs and Mods
That is also a possibility. I'll investigate it further this weekend Sent from my SAMSUNG-SGH-I747 using Tapatalk -
top n bottom end rebuild. won't idle
threequarterthrottle replied to 12-o-clock-wheelie's topic in Banshee Repairs and Mods
No tors here, so the carbs shouldn't ever affect spark. I checked sync so I know they're installed and sliding correctly. I don't think the washer is the root problem in your case. It definitely needs to be in there, but may not be causing all of your symptoms. You do have verified spark at both plugs right? And you're sure you got the flywheel key in and aligned correctly? Sent from my SAMSUNG-SGH-I747 using Tapatalk -
Understood. I couldn't see the necessity, but never hurts to ask. Removing the washer actually changes the position of the main jet significantly, bringing the needle much deeper into the jet. Sent from my SAMSUNG-SGH-I747 using Tapatalk -
Fwiw, my carbs don't have the plastic inserts(unless he's talking about the floats?) Necessary? My carbs seem to deliver the correct amount of fuel now that I rebuilt them, but of course now I have no spark(I've had this thing a month and still haven't rode more than a mile) I feel your pain dude Sent from my SAMSUNG-SGH-I747 using Tapatalk -
Ebay stator
That's enough bad press to keep me away from them. Thanks guys Sent from my SAMSUNG-SGH-I747 using Tapatalk -
Ebay stator
I know, too good to be true Sent from my SAMSUNG-SGH-I747 using Tapatalk -
Carb issues resolved, New issues arrive. New needle and seat resolved my leak, had her idling fine and running like a top. Now, every time it gets warm (not hot, like a quarter mile away from the garage) my spark dies. I guess I'm gonna spend my pod money on a stator, wiring and switches checked okay. Some day I may get to ride this jewel. Sent from my SAMSUNG-SGH-I747 using Tapatalk -
There is an abundance of cheap Chinese made aftermarket stators on eBay. Are they junk, or a deal? Sent from my SAMSUNG-SGH-I747 using Tapatalk
It would be easy to build a shield along the bottom to slow splashing without decreasing airflow , as well. if there is a significant difference in flow between the pods and an open air box. I suppose that is the question -
While I'm asking dummy questions: which is better, gutted air box or filter pods? And at what point do i start questioning the flow capabilities of stock carbs? I'm thinking about a trail port and fresh top end this winter, reseal the bottom end and hope it's all fine inside. I've also seen people selling timing advance keys for the flywheel, claiming big power gains. I want to be able to run 93 comfortably. Damn i need that clymers manual, some engine specs would probably answer half my questions -
K&N pods fiilter
threequarterthrottle replied to Banshee SE's topic in For Sale - Parts & Accessories
Beside me, check the for sale threads. Dude has three air boxes, one doesn't really look like a shee box. -
K&N pods fiilter
Was looking to trade for the filter pods, if they'll work and you still have them, with wraps. If not, I won't be able to sell until i upgrade my filters. .. can't be riding dirty lol -
Cool, I'll definitely have to pick some up at that price. -
K&N pods fiilter
I am. I have an air box with filter (after market, can't remember the brand) and lid. Do you have the wraps for those filters? I mostly trail ride so I would definitely need those. Again, I need to get home and measure the od on my carbs, 60 mm seems huge in my mind. -
Wiseco piston set 795M06550
K thanks -
K&N pods fiilter
I'll have to Mike my carbs, that id seems huge. May not be able to use them -
K&N pods fiilter
I have one with the snorkel removed, the previous owner put a piece of wire mesh over it. Take pics when i get home. -
Rhetoric
Not trying to be a dummy, but what's the difference in rods? I keep seeing "long rod", is it a production change through the years, or a mod? Thanks for entertaining my ignorance. -
Good idea. I'm going to get the idle in order and low throttle response suited before i go wrecking plugs to verify what I've tuned by feel for years. Not being a smart ass, just saying why hack a plug when you're certain it's not right. I've tinkered with engines my whole life, made a living at it for seven years, just got bored. climbing trees with chain saws is way more interesting :-), and the money is much better -
The 280s run flawlessly at wot, i haven't done a plug chop to verify though. I need to get the needle/seat replaced on the right carb before i can get a fair analysis. The wife is picking up my carb clamps (yes, they were missing. imagine explaining to a dealer retard that Yamaha fucked up with the tors, and most people went back to the old style) tomorrow, she's getting new plugs for me as well. -
I'm going to try 27.5 pilots, the stock 25s leave a rough idle. I don't know what the clips are set at, but i don't have any mid to full throttle issues, so i wasn't too inclined to screw with them. After a thorough carb cleaning, it runs much better and almost idles. Compression test and leak down test are in order, time is gold right now. I get home from work at nine on Friday, and leave Sunday afternoon.
