dildaledo
About dildaledo
  • Birthday 08/23/1987
    Northern Michigan
    1988 Yamaha Banshee Toomey T5 .030 overbore Pro X pistons Stock 26mm Mikuni carbs w/ tors delete
dildaledo's Achievements
  1. Went for a short ride yesterday since the weather was decent up here. Lost a spark arrestor on my T5, couldn't find it. Started heading back very slowly so the packing didn't blow out, and my oil plug rattled out. I knew the set screw in the silencer would go eventually. I've lost & found it 3 times but this time she's gone forever lol. I don't know if toomey had a brain fart with that design but a couple of set screws doesn't sound like the best way to secure an $80 spark arrestor. Or maybe someone "customized" the silencers, no idea. I ordered a new plug through my local powersports store and it will most likely be here Tuesday, but I need to do some jetting changes and need a temporary plug. So, does anyone know the thread size!? And if you know anything about T5's what should I do about the spark arrestor? This is a frame up rebuild of an 88. I'm not trying to compromise because I'm impatient, but also not trying to buy an $80 spark arrestor that will fall off. I have the "tea cup" looking ones, they came on the bike and I've been wanting to change to a low or mid range pipe eventually. I know people that have throw fmf silencers on but I feel like the two pipes are too different and will effect performance. Any help will be appreciated. Theeeenks
  2. the most common term in my house is "that sucks... x2" lol They're more than worth the headache when they run though.
  3. Orange is pos, black is neg. when you installed the new coil, do you have spark every kick or is it intermittent? (Every once in a while) Like ginger said, check your flywheel and pick up gap. Pull the stator cover off (left side) there's a little black box. There's 2 tabs on the outside of the flywheel. When the tab passes the pick up coil there should be just a small gap between the two. I think it's supposed to be .018 or right around there anyway.
  4. I like the one with audio so I can hear a "beep" checking continuity.
  5. I've read that it doesn't matter but there is a + & - on the coil. The + is closest to the motor. Do you have a multimeter? If not, you can pick one up at any auto parts store for around $30 bucks.
  6. I know what you mean brotha! This site has an incredible amount of info. Every problem that has ever existed on a banshee with a thousand answers as to what it MIGHT be lol. It can be overwhelming. I'm just now getting used to the site so I've always read through other posts to try to find the exact symptoms my bike was having. Doesn't seem like any 2 banshee issues are the same haha. If you need any help in the future shoot me a message and I'll try to lend a hand! 2 strokes aren't hard to work on, but 2 cylinders makes it harder
  7. This is the order I would go in. Check for spark first. Weak spark will make it difficult to start If no spark, start checking grounds first. (I've also had my coil wires pop off the + - terminals before) If you have good spark Pull fuel line from petcock, put a cup under and turn gas on to make sure there's a good flow. Check choke tube between carbs didn't come off. Make sure carbs are synced and caps are on tight, intake boot clamps are tight Pilot or main jet could be plugged up. If you pull carbs off, inspect your reeds. If the petals have a gap, chip, crack, etc. it won't want to start. If you have spark and everything else checks out, throw some new plugs in and see if it fires. If nothing still, leak down test. Compression test.
  8. Did you get this resolved? Hopefully you have, it's been a while since the post lol. I was dealing with a similar issue recently, it ended up being my float height and the float was also tweaked a bit. Straightened it out and shee was screaming Also just discovered my tors delete was only half done(bought it with tors removed) I started reading about idle screw adjustments but my carbs only have air screws. So I'll be tapping some carbs tomorrow. Just a couple things to check. I screwed up just about every step of the way building my banshee. I learned the hard way but I'm happy I learned what not to do, and why not to do it.
  9. Hell yeah I appreciate the wishes Got up early and I'm doing a run through. If you can help me out on 2 things it would be trill. When I bought the quad, the dipstick was cracked off at the end (it's not in the case) but I forgot to get a new one so I'm trying to figure out the length of the dipstick! I filled the case with 1.6 qt like a month ago but just want to double and triple check ya feel? And, where do I post random questions on this site? Everyone's talking about staters in the "shout box" and I didn't want to be the torrettes guy and blurt out a f*ucking dipstick question lol. Just type in the "what's on your mind" box??
  10. Holy hell THANK YOU!!! A 3 year old post solved my 3 week brain fart! I just tied my cdi ground to the stator ground and after 2 years, my banshee is purring like an autistic kitten (haven't been able to tune anything yet). Calling in sick tomorrow to go blow some dirt
  11. Thanks for the link. I think I was missing the lower mounts. I bought the full rebuild bolt kit and it came with the 2 straight long bolts but not the ones with the rubber grommet and bracket.
  12. Very new to this. 88 banshee, 0.030 over, Toomey T5 exhaust. I'm at about 900ft elevation. I bought the quad with 2 left carbs so I'm replacing them. trying to figure out what size carbs/jets I should run. Mostly just trail riding this season. I'm thinking 28mm carbs and clueless on jetting. I have no air box yet the quad is completely stripped down to the frame and I'm trying to put it back together the right way. HAAAALP!
  13. Hey guys, new to the site! Looking to replace motor mount bushings on my 88 banshee. I keep running into a different kind of mount. Mine are just 2 straight bolts (one long and one slightly shorter) if anyone could tell me where I can pick some up I'd greatly appreciate it!
