@premiumsdd2
Everything posted by @premiumsdd2
  1. I knew that would be an issue that's why I took all the proper steps I thought were necessary like tapping things off and plugging holes minus the water tube hole.
  2. well tell me how to post pictures then because I've tried it and it wouldn't work
  3. It's got McDonald's color scream and me and a couple buddy's came up with the name McDanks for the restaurant hense the name for the quad
  4. Note* I should have posted this in a different topic forum
  5. So I figured I'd start a build thread for my 96' banshee. This project started in June shortly after I bought the quad in May. It all started when the notorious idler gear went out. This is when I first got it https://imageshack.com/i/p89lhFK1j It was what I wanted, for the most part. It had K&N pods and +4adv timing, twist throttle and that was it. it also came with a manual, paddles and a title witch where all a bonus. shortly after that I got new a new chain and sprockets for it for obvious reasons lol https://imageshack.com/i/p8liSUQRj https://imageshack.com/i/p3rTpoATj https://imageshack.com/i/pbhxCWEuj https://imageshack.com/i/p5Fqa4bIj Then it was off for the first "big" trip to the the silver lake sand dunes https://imageshack.com/i/p7YXiWjPj https://imageshack.com/i/hlLpzIhkj https://imageshack.com/i/hl0OYBMSj Then it happened the "Big Bang" https://imageshack.com/i/paDm2VCWj https://imageshack.com/i/p8Zfs14Ij Then began the year down https://imageshack.com/i/pblyit83j https://imageshack.com/i/p3qExWdtj https://imageshack.com/i/hlWk2D1Hj https://imageshack.com/i/patHoP9Aj https://imageshack.com/i/hlhcxxKxj Once all that was left was to split the cases this is where I got worried because I've never had any experience doing any thing like this but it went fine in the end https://imageshack.com/i/p3n3ZLX2j Then came the re-assembly, I bought a new/used bottom case off eBay with all the gaskets and bearings and what nots https://imageshack.com/i/p3n3ZLX2j https://imageshack.com/i/p8SqoO5tj https://imageshack.com/i/p30fn2Anj https://imageshack.com/i/pakeiQwCj Then like any banshee owner I wanted to add my own unique touch per say, something that sets it appear from the rest so I went with a bright red for the bottom end to color match my tank plastics https://imageshack.com/i/p85kT1GIj https://imageshack.com/i/p8RYmG9Ij https://imageshack.com/i/p5DnspAlj Then came putting the trans back in the frames do putting the clutch basket and all that back https://imageshack.com/i/hl23tyDij https://imageshack.com/i/pbQ3nXKTj https://imageshack.com/i/p56BJ98Dj https://imageshack.com/i/p52VpSWjj Then I put on a ton of stickers because it's a no brainier that stickers add a ton of horse power and makes the girls wet https://imageshack.com/i/p5T2pfQ8j I moved the key from its stock position to the front right fender as you can see but I remembered seeing quite a few people putting them under the seat so I did that instead. I used a 1/8" piece of aluminum off a running bored from a truck some one had thrown away at where I work so I "tried" to cut it and polished it up pretty nicely https://imageshack.com/i/pb8MK8BOj https://imageshack.com/i/p8zYyu9Wj Sense I go to a half a day of "collage" every day for welding I was able to save my clutch case by having a buddy of mine tig weld the crack in it solid https://imageshack.com/i/p88O1ifNj https://imageshack.com/i/p89lhFK1j That's where I'm at as of now Im just waiting on my kick starter seal to come in the mail then the bottom end will be complete. This build will take a while so stick around see what's going on, let me know what you guys think so far!
  6. Haha I'm not sure of how else to explain it, and I know this has been covered before but as far as a cdi box I noticed when I bought the machine the box was red in color but when I buy a new one should I stay with oem and where is the best place to buy one? eBay or a local dealership?
  7. So I'm waking up an older thread but I started this one so what ever but as all ready said my banshee would physically run backwards only when starting, if I shut it off and re started it, it would most of the time run normal. I got the bottom end back to gether and the fly wheel key was NOT sheared and the timing plate bolts were tight. I'm lost as to what it could be, I'm not an electrical expert but maybe a cdi? Also I am going to start a build thread soon so look for that, I'm not cutting any corners on this build so that should be interesting. Thanks guys!
  8. Here's some pictures of the situation
  9. It's got plus 5 timing on it
  10. What do you guys think about a whole new motor and trans?
  11. I got the chlutch cover off and the bottom case is fucked pretty good and so is the clutch cover. The grear behind the clutch that the kick stater spins has gone out, I'll pull the clutch off and see what I can figure out.
  12. So I bought a new shee and rode it a few times, ran beautiful. It's got +5 timing, pod filters and that's it. But here's the problem I guess the bottom end was gone through previously because the last guy had accidentally cracked it working on it. I went to silver lake to take it on its first big adventure, the 2 simple mods on it help out to say the least. once I got on the dunes I shut it off to get a few pics then when I started it up it litterly ran in reverse, I shit it off again and it was fine. It did this almost every time I started it back up, note that previous to this it had never done it. I had done 2 full laps of the dunes then on the end of the second I heard a retteling from my bottom end kick start erea, I emedietly shit it off. I started it back up, my kick starter caught them slammed forward, my bottom case and my black case on the right hand side both cracked and puked out oil. So I guess what I'm trying to figure out is what to do now. Thanks
  13. Who's gonna be up there this week end?!?! I'll be there on Sunday all day, look for the red & yellow 97' all stock!
  14. Eric looks like a fag and I'm a killer not a homo
  15. im the badass because I killed the shit out out of the mole
  16. bad asses don't follow the rules...
  17. Damn spell check
  18. Ok so I haven't been on the HQ in a couple days but I thought I felt the need to start a new post. It has Aboslutly NOTHING to do with banshees but I thought it was pretty funny Ok so I'm I the 10th grade and last Sylvester I had cooking class/home ec, and one day I was cooking potatoes or some shit and all the black kids crowded around the window and yelled "oh shit! It's a rat!" So I went over to the door, pushed every one out of the way, ran out there and stomped the hell out of it! (Normally I wear boots to school) but any ways I got blood all over my Vans and the teacher wouldn't let me back in the class room... I had to get the janitors to clean it up off the floor, washed my shoes and all that good stuff and needless to say I still get shit about it from my friends. It turns out it was a baby mole but what ever, lmao.
  19. lol mid Michigan, and I see there is a lot of good deals in that area it's just far for me to drive
  20. Craptors can't hang with a shee
  21. I can't pit pictures
  22. My dad sometime in the late 80's
  23. How do I post pictures?
