Mr.banshee
Everything posted by Mr.banshee
  1. It seems to getting better so...change main jet to 260, needle meddle position, adjust air, check and I think it will be way much better.. Στάλθηκε από το SM-G935F μου χρησιμοποιώντας Tapatalk
  2. I am curious and waiting for jimmy2450 to tell as..I hope we help him.. Στάλθηκε από το SM-G935F μου χρησιμοποιώντας Tapatalk
  3. Yeah right but you must consider that on a banshee piston movement we don't have the same time ignition coz the pistons don't have the same movement (up and down together) so in this case depends which cylinder stay out of fuel first.. and on this case at 25% of the position of the throttle.. Στάλθηκε από το SM-G935F μου χρησιμοποιώντας Tapatalk
  4. Yeah bro.. but he said the bike start good and have tons of power..his problem is at 25% of the position of his throttle.. Στάλθηκε από το SM-G935F μου χρησιμοποιώντας Tapatalk
  5. Have check also your pilot jet? You said your problem is on 25% of your throttle.. check for dirt and if you don't have to go bigger rise your needle as I told you, check and tell me.. Στάλθηκε από το SM-G935F μου χρησιμοποιώντας Tapatalk
  6. If you have low temperature right now you have more oxygen, so the ratio fluel to air is different... try this and tell me.. Στάλθηκε από το SM-G935F μου χρησιμοποιώντας Tapatalk
  7. ...also first check your pilot jet if is clean.. Στάλθηκε από το SM-G935F μου χρησιμοποιώντας Tapatalk
  8. Try to raise up the needle 1 klik and test again.. Στάλθηκε από το SM-G935F μου χρησιμοποιώντας Tapatalk
  9. What's the set up of your cards? Στάλθηκε από το SM-G935F μου χρησιμοποιώντας Tapatalk
  10. How much for the shocks? Στάλθηκε από το SM-G935F μου χρησιμοποιώντας Tapatalk
  11. Do you ship to Greece? Στάλθηκε από το SM-G935F μου χρησιμοποιώντας Tapatalk
  12. If you can find out how much it would be great... Στάλθηκε από το SM-G935F μου χρησιμοποιώντας Tapatalk
  13. Do you still have the swing arm and if yes do you ship to Greece? Στάλθηκε από το SM-G935F μου χρησιμοποιώντας Tapatalk
  14. Do you ship to Greece? Στάλθηκε από το SM-G935F μου χρησιμοποιώντας Tapatalk
  15. Do you ship to Greece? Στάλθηκε από το SM-G935F μου χρησιμοποιώντας Tapatalk
  16. Stock swingarm lenght is 18,1/2 inch.Duncan racing for mx use suggest 17,5 inch and for tt use suggest 16 inch.I thing it helps...
