Wedig Banshee
Everything posted by Wedig Banshee
  1. Make sure you put the seal in the correct way, it is labeled coolant on one side of it. Also the new Yamaha bearing is a little different, it has a plastic seal on one side. The research I did the plastic side should face the oil, it acts as a filter to keep the clutch and transmission debris out while still allowing oil to lubricate the bearing.
  2. Was their ever a fix for the sticking throttle ? I have that same issue on (2) banshees that I just put new cables and twist throttles on. I talked to motion pro R & D and they suggested that the carb breather port is partially plugged causing a vacum on the slide not allowing it to rest on the idle stop. I am going to check it out and also extend the breather lines, I might add some sort of filter also. I think small dust particals are getting into the slides via the vent port on the carb causing issues.
