sheebad1990
    90 Yamaha banshee
sheebad1990's Achievements
  1. I apologize I sold the pwk. I have 28mm round slide mikuni.
  2. Why so small on the main jet.
  3. I have a 4mil bored at 66mm wiseco 795 series. I have fmf phatty pipes and power core 2 silencer. I also have 28pwk. Could anyone help with jetting. I am around 800ft above sea level. With dune ports.
  4. No you don't need it
  5. Ok I found the problem. easy fix. Idle screw was wiggling lose. No air leaks but when I first start now it idled high then goes to normal but fine afterwards
  6. Ok thanks for the help. I will be checking that in the next couple days. Will update soon.
  7. Oh One more thing do I have to split the motor to replace crank seal if that's the issue. But I have lost any oil. Thanks for advice.
  8. Could I turn a compression test into a leak tester?
  9. How would I pink point where the leak is coming from.
  10. Can anyone help my banshee runs fine at first. Starts first or second kick. After riding awhile it idle high. I shut it down yesterday. Started it today and only one side had exhaust coming out. It idled high and just shut off. Can someone please help
