Jeff1.8t
Jeff1.8t's Achievements
  1. Someone is selling a nice full set of R2s on here for $350? How much are toomeys
  2. 6105130270 text
  3. I was seeing if I could get a straight up trade but I guess I could add some
  4. Want to trade toomey t5 for rocket r2s or original rockets
  5. Trade my 2002 white and black plastics for old style red and white, white and blue or purple and yellow plastics. Text 6105130270
  6. I think your talking about the carb choke tube and yea that's on right
  7. Everything is clean in the carb, didn't check the reeds because I figure what is the point because it ran great before and didn't even go near the reeds. But what if the bowls were switch what would that have affect?
  8. Can the tors system still interfere if the wires are disconnected? My left side carb was leaving out the overflow I fixed the leak but took off both carbs to clean, put everything back together and it won't star unless you spray some break clean on the filter to get it going. It would start with one kick before and idol great. The carb choke tube is on, no air leaks, compression is good. The right side will missfire like it's running lean, when I spray break clean in the right carb it runs better. Seems like a fuel issue, I have the tors disconnected from the carb wire and black box that's it. Can it still interfere?
