Can the tors system still interfere if the wires are disconnected? My left side carb was leaving out the overflow I fixed the leak but took off both carbs to clean, put everything back together and it won't star unless you spray some break clean on the filter to get it going. It would start with one kick before and idol great. The carb choke tube is on, no air leaks, compression is good. The right side will missfire like it's running lean, when I spray break clean in the right carb it runs better. Seems like a fuel issue, I have the tors disconnected from the carb wire and black box that's it. Can it still interfere?
