paultrombley98
Everything posted by paultrombley98
  1. OK thanks! Sent from my One X using Tapatalk
  2. Can I just eliminate coolant bottle and just run the vent lines towards the ground? Sent from my One X using Tapatalk
  3. pm sent Sent from my One X using Tapatalk
  4. I'm in need of an inner clutch hub or a complete clutch quickly and I was wondering if anyone has one they would like to sell? Thanks Sent from my One X using Tapatalk
  5. And the motor has zero hours on it ever since the rebuild because I don't have a clutch hub. Sent from my One X using Tapatalk
  6. I'm looking to sell my banshee these are not the most recent pictures of it I now have everything back on together on the bike except for the clutch. It needs a clutch hub then it will be good to go. This is what the bike has on it Dura blue axle works front suspension DG nerf bars Vitos stock stroke crank Vitos OEM pistons all new gaskets and seals pro taper bars I don't know what kind of a arms( maybe someone here can identify them) And there is probably a few other things iam forgetting. Make me reasonable offer, I am open to trades. I also have an ownership for it. Iam located in Windsor Ontario Sent from my One X using Tapatalk
  7. Same thing happened to me I was coming to a stop and it made metal to metal sounds and I tried to kick it over and it was seized. I turned out to be the right side rod bearing. Took it apart and the right rod wouldn't moved because the bearing was destroyed. Sent from my One X using Tapatalk
  8. Haha I didn't even notice that Sent from my One X using Tapatalk
  9. Do you still have the complete clutch assembly? Sent from my One X using Tapatalk
  10. Yeah you guys were right it doesn't go all the way into the intake. Thanks for helping me with this I actually thought there was something really wrong Sent from my One X using Tapatalk
  11. I will check again when I get home then Sent from my One X using Tapatalk
  12. Its a hole right through and its on both cylinders but the one on the other is a bit smaller. Sent from my One X using Tapatalk
  13. I was looking at my cylinder and noticed that there was a small hole. could any one tell what could have caused this? Sent from my One X using Tapatalk
  14. Do you still have the 4mil hotrod crank? Sent from my One X using Tapatalk
  15. Any where below London I'm from windsor Sent from my One X using Tapatalk
  16. Just wondering if the is anyone from southern Ontario here and if they know of any good places to ride Sent from my One X using Tapatalk
  17. I'm selling my OEM crank it needs to be rebuilt the right side rod bearing is toast. Sent from my One X using Tapatalk
  18. How much would you sell the crank for? Sent from my One X using Tapatalk
  19. Sent from my One X using Tapatalk
  20. Will rental Handel bars for a raptor work on my banshee?? I just bought these and wasn't completely sure? Sent from my One X using Tapatalk
  21. thanks man I really appreciate it! I Sent from my One X using Tapatalk
  22. So do you run it with out your idle screw and does it run fine? I ordered a new one already except I do want to ride this weekend and it will take a week and a half to get here Sent from my One X using Tapatalk Sent from my One X using Tapatalk
  23. So do you run it with out your idle screw and does it run fine? I ordered a new one already except I do want to ride this weekend and it will take a week and a half to get here Sent from my One X using Tapatalk
  24. So I should be OK if I cover the hole? Will it just not have an idle? Sent from my One X using Tapatalk
  25. Sent from my One X using Tapatalk
