i have a great little bike for sale, just completed. it began as a 1996 scrambler, the chassis has a streched swing arm, the motor cradle was lowered and moved back also the front a-arms were moved forward, it is set up ridgid in the front with a strut in the rear. it has a brand new 40mm modd quad rear axle and hubs with sealed bearings, new 90 tooth 530 rear sidewinder sprocket with extra fronts from 12-17. the motor has just been completly gone through with maybe 20-passes on it and has brand new wiesco forged pistons, rings, and seals. stock bore and stroke with no porting, the motor is a total loss set up with no stator but it does have a brand new ballistic 16 cell evo lithium battery for the electronics, fan, nitrus, neons, ext, and a new ballistics battery charging system. new drag pipes and clutch cover built by dave moore, the chassis work also was done by dave. lectron 38/40 carbs with power rings freashly rebuilt by kevin at lectron with billet bowls,new billet thumb throttle, and cables from lectron with k&n filters. brand new data logging digatron dt-64, tach, 2- egts, jackshaft sensor, h2o sensor and software. a almost new set of sand blaster 16 paddle 26x12 rears with smooth buffs up front. i have 2- extra rear clutches, helix's, springs, belts, carb needles. best to date w/ a 300 lbs jockey was 4.78 at 63mph with a 1.67 60". still got some more in it but needs clutch tunning and gearing(a little more knowledge). the table in the photo goes with it as i will no longer need it. askin $5,500.00 for everything. if you have any questions feel free to ask ill do my best to answer them. if you want any video of it running or more photos just ask.
gator 210-394-4346
