Budwiser420
Everything posted by Budwiser420
  1. I hope so , I was going to do a leak test to see if I have a blown crank seal .. Someone told me that's what it is .. Hope not
  2. Yeah I have 35mm carbs with no boxes on top so I don't think I have tors . I will try and test all of those components , and I have 35mm carbs with no air box just filters and they don't have any wires going to them so I'm pretty sure I don't have tors . Tors is the system that won't let you rev high if your parking brake is on right or am I way off? ( btw I have parking brake delete kit on the rear ) also does anyone kno why oil would be coming out of the back like I explained at the top? It only happend when I kick it over a bunch of times in a row
  3. Just picked up this banshee not to long ago and haven't gotten it to spark , and there is some oil leaking from a (vent hole , someone has told me ) under the swing arm mount and I don't kno what that's from? I'm an auto mechanic so I'm not too stupid with this stuff but need some help cuz I'm stuck at this point . If your from Maryland a d live towards Clarksville and willing to come by we can try n figure this out , drink some beer and ride , also will be payed . And if anyone just wants to talk on the forum that would be appreciated as well , pictures and be sent if needed thanks.
  4. I dint think it would overflow even if I put 100ml more than needed
  5. Measured it out to what the factory said it should be , and made sure there was no aftermarket cases to make sure I didn't need any extra
  6. Didn't have a dip stick , It was just a plug , but I put the rite amount of oil in it ..
  7. That's the one . Doesn't come out to much but every few kicks / pushing it from one side of the garage to another some will come out . I appricate you spending your time to help man. What do you think I should start off doing to stop this problem .
  8. How should I go about doing a leak test ? And it's weird oil only comes out somtimesand I've traced it back to the hole below the top swing arm / shock mount
  9. Thanks man , is there anyway you could post a link I'm still looking for that feed
  10. . So I should take the red and black wire that came out of the key and tape / crimp them together ? And I'm pretty sure I don't have tors if I have 35mm carbs rite? Or does that system come in all banshees and aftermarket carbs
  11. So I should take the red and black wire that came out of the key and tape / crimp them together ? And I'm pretty sure I don't have tors if I have 35mm carbs rite? Or does that system come in all banshees and aftermarket carbs
  12. I put the allotted amount of oil in there , I really noticed it when I was putting it away goin up the ramp to my shed and it started dripping out. Looks like the hole has threads ? Thanks for the help
  13. I got a new bike and kicked it over to see if there was spark and some oil started coming out of the rear , thought was a dumb ass and bought a bike with a messed up case then really followed the trail to where it was leaking and there is a bolt missing on the top of the case, underneath the swing arm linkage , I can't post pictures on here for some reason but if anyone can help it would be greatly appreciated , I'm just looking for a size on that bolt and also maby a thread size / count ?
  14. No lights , no brake light and I think there's a block off kit for the back parking brake. I think the tether switch is hooked up rite will go look , wires around the bike are clean.
  15. Not sure , some guy just wanted it gone and he hadn't messed with it in about a year, I'll go and clean everything up rite now and see if that helps but the bike it pretty clean , didn't see and corrosion* . Thanks for helping and the fast response man.
  16. Just picked up a new bike ,threw a few new parts on it (nothing electrical ) , new fluids , and kicked it over with one of the plugs out and it doesn't spark , the key was removed by the person befor me and replaced with one of those tether things . I don't kno much about electrical so was looking for some troubleshooting help from some banshee lovers like myself . Can post pictures if needed i think idk because this is my first posting , thanks in advance !
  17. Need help with getting spark on the new shee I just got
  18. What's size are the intake boots ?
