Mxz800rs
Everything posted by Mxz800rs
  1. Ok, i cant see the dot through the carb windows!!! what would i have to do to adjust that?
  2. Ok so slides are in the correct way they should be... Could this be a crank bearing or crank bearing seal???
  3. Ive have tried alot so far but, yes the tube is in place, new boyseen power reeds (no difference in the way its acting when i recently installed), carbs are good and clean, as far as the slides being right im pretty sure they are in the right sides, what would happen if they werent? and i dont think they can go in the carb two way because of the pins but im sure they are right for sure.Spark is good starts up no problem and has lots of compression, although this problem was here and then i rebuilt the topend and that didnt seem to make a difference (compression was 110psi both before the rebuild and 110psi both after the rebuild ????). its definitley not a parking brake issue because its been deleted for a while and i even tested it by reattaching the wires. could this really be a jetting issue??? my concern is it not reving an hitting powerband in neutral as any other banshee or all dirt bikes do (ANYMORE as in it did last summer) when i try to rev it sounds and looks like its choked out from being so rich and pooring smoke out the exhaust (especially when i rev it and let off, it smokes thick smoke after i let off and whinding down), so it wont allow the bike to rev out or hit powerband and get that high pitched scream she used to! When i try and drive it on the road first, second and most of third will bog out until she clears out a bit from the oil or gets really hot will she then start hitting power band but reving out very early... and once shes that hot theres very little smoke coming from the silencers, neutral will still bogs and when im down low in first or second sometimes but other wise she feels almost normal but not high reving like she used to be... let me know what you think need some fresh ideas. been battling this for a while now...
  4. Hey guys new to the site, had banshees for years now ran into a problem I can't diagnose and need some help! Here's some info on my bike: 2003 shee Tors delete kit Did just a fresh top end complete (stock bore namura pistons) Compression 110psi both PC pipes Toomey silencers Stock air box K n N filter NO lid Stock carbs Boost bottle 290mains 27.5 pilots I believe Bike ran great all last year until the tors unit acted up and wouldn't let me idle. So I got the delete kit install it and then wouldn't hit power band and just sputters and bogs everywhere. The banshee smokes alot more than normal at idle. She idles great and sounds good low end no bog but wot rev out. So then I compression tested it and got 110psi so I decided to rebuild the top end with new pistons ring gaskets etc. After the rebuild... Same exact thing won't rev out at all. Tried couple different jets but nothing changes really. If I ride it for a little she gets real hot the powerband starts working from 3rd gear on but feels like the gears are Sooo short for some reason??? Please any other ideas? Like I said I tried leaning out with jets and air fuel and doesn't change much??? Also recently she i start it up cold she will rev high for a couple mins and then idle good...??? Thanks guys
