Ive have tried alot so far but, yes the tube is in place, new boyseen power reeds (no difference in the way its acting when i recently installed), carbs are good and clean, as far as the slides being right im pretty sure they are in the right sides, what would happen if they werent? and i dont think they can go in the carb two way because of the pins but im sure they are right for sure.Spark is good starts up no problem and has lots of compression, although this problem was here and then i rebuilt the topend and that didnt seem to make a difference (compression was 110psi both before the rebuild and 110psi both after the rebuild ????). its definitley not a parking brake issue because its been deleted for a while and i even tested it by reattaching the wires.
could this really be a jetting issue??? my concern is it not reving an hitting powerband in neutral as any other banshee or all dirt bikes do (ANYMORE as in it did last summer) when i try to rev it sounds and looks like its choked out from being so rich and pooring smoke out the exhaust (especially when i rev it and let off, it smokes thick smoke after i let off and whinding down), so it wont allow the bike to rev out or hit powerband and get that high pitched scream she used to! When i try and drive it on the road first, second and most of third will bog out until she clears out a bit from the oil or gets really hot will she then start hitting power band but reving out very early... and once shes that hot theres very little smoke coming from the silencers, neutral will still bogs and when im down low in first or second sometimes but other wise she feels almost normal but not high reving like she used to be...
let me know what you think need some fresh ideas. been battling this for a while now...
