shee1992
Everything posted by shee1992
  1. Leakdown done no leaks and caps are oem new and i have even swapped the entire coil setup off another bike and no luck. Maybe i got a bad cdi right out the box
  2. Not jetting guys, it does it at every rpm when a load is on it. In nutreal it revs as it should. It had a ricky stator and i replaced it with oem. I replaced coil, wires and cdi from dyna, caps are oem. But i have swapped all these parts from my other bike that runs and no change. Only part i could not swap was the cdi cuz this bike is the newer plug and my other are not. Also air leak test was perfect.
  3. My bike started cutting up or breaking up about a month ago. I was pretty sure its electrical so i have replaced coil, wires, caps, stator, cdi, flywheel, compression is good and its still doing it. Any help would be greatly appreciated.
  4. I tried cpi and shearers on my serval and I picked the shearers hands down for my riding. I dont trail ride and the shearers pull harder up top, I would love to try some snipers though.
  5. 1) What type of aftermarket exhaust do you have? shearer inframes 2) What type of airfilter do you have? K&n air pods 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all No box at all 4) What is your elevation? sea level 5) What size pilot jets are you using? 50 6) What size main jets are you using? 170 7) What temperature is your Banshee jetted for? 80-95 8) Do you have a port job? clean up 9) What kind of carbs? keihin pwk 10) What size carbs? 35
  6. I have 165 psi and timing set at 5. Pretty sure 89 octane is not gona cut it. Im at sea level. I got it running pretty good today. 50 pilot and 170 mains, still a tad rich, gona play with it some more tomorrow.
  7. I just finished a new motor and wondering what jets and timing what be a good starting point. 421 serval(just cleaned up) 35 pwk's(pods) CEL needles .031 base gasket vf4 24cc domes shearer in frames 110 gas sea level
  8. I was going to order from Jeff at fast, he did the cylinders.
  9. looks like im getting some shearers, is the show chrome worth it or just get the reg chrome finish
  10. ok I just had a few guys tell me theirs ran better with the cpi's but those guys had real basic port work with stock stroke.
  11. Im putting my banshee back togather and need input on which pipes. mods are 4mill, stock cylinders dune port, 19cc domes, 35 pwk's, vforce4, +4 timing. I mostly use it for 300-500 races as a play bike. Im looking at either cpi or shearer inframes.
  12. ok, so whats the best head, cool or the noss head, i was told i dont have to change the head bolts on the noss head. i run pump gas also so what dome size. they feel faster but just dont hang when i drag them down the road.
  13. I picked up a couple banshees and one has fmf sst pipes jetted and the other has t-5 pipes both have 2n1 k&n filter. i have a hrc 450 and a kfx 450 and they both pull on my banshees, i know they arent really modded with just pipes but whats the most simple and reliable mod to do to them to get them on par with my 450s. my trx isnt much faster but does pull them a tad. thanks im new to the banshee but already loving them.
