draggins10
Everything posted by draggins10
  1. I"m looking into getting a new extended axle but I do not want it to be any wider then my front is. Right now I have +2+1 a-arms, what size axle would put me at the same width or slightly more narrow then my front end is?
  2. Got it out, swinger is back on. Thanks though I appreciate it. I might need you to sync my carbs after I change my throttle if you can. Thanks again for the offer
  3. Finally got them out. Cut a slit in them with a sawzall then used a chisel to bend them inwards. Thanks for the ideas
  4. Good idea. I'll continue to spray them with pb blaster over night
  5. Haha what's up Carl. This is Nick from Massapequa, you just fixed my blue and white banshee a couple weeks ago actually and told me I needed new swingarm bearings too. My friends gonna give it a go at these out tomorrow; but if we still can't get them out I'll give you a call. Thanks
  6. Great seller! Fast shipping and packaged extremely well.
  7. I tried all other suggestions and still cant get this bitch out. Anyone have a stock swingarm for sale?
  8. grind it out with what?
  9. Thanks Apeik, I'll give that a try. Here's a pic of what I'm dealing with btw,
  10. I'm trying to replace the swing arm bearings but both of the old bearing races are stuck inside the swing arm. Any tricks to get these out without damaging the swingarm?
  11. ill take front bumper
  12. Are any site sponsors having a black Friday sale?
  13. Massapequa NY
  14. Selling 2 stock banshee carbs. They are in working condition. Needs a new choke plunge, the one that is on it does not stay out when pulled. Also the slide springs have been cut for easier throttle pull. I believe they come with 25 pilot jets and 280 main jets. They could use a cleaning externally but worked fine before I took them off. 60$ or trade? Looking for a front bumper
  15. draggins10
    rear rim
    Location?
  16. draggins10
    rear rim
    Looking for 1 stock rear rim. 9x8.5 thanks
  17. It idles fine. I don't think there is an air leak because it ran fine before I changed the carbs. So to go richer on the needle I move it down one groove right?
  18. Mods are fmf pipes, +4timing, 4 mil crank with spacer plate,boysen reeds, uni filter w/o lid and these 28mm mikuni carbs
  19. Just switched my stock carbs for mikuni 28mm flat slides. As suggested I tried out 300 main jets, 30 pilot jets and 2nd clip on the needle. The best I got it running was with the idle screws 2 turns out and the air/fuel screws fully turned in, and it was still breaking up in the low to mid range but it seemed to pull fine up top. Where do you guys think I should go from here with jetting?
  20. Needle second from richest clip, Is that second from the bottom of the needle? Like this?
