milto29
Everything posted by milto29
  1. I've seen stock cylinders destroy Cubs or DM. You have to find a builder that thinks outside of the box. That's we're a lot of people FAIL in this. Bigger isn't always better. Especially if your like me that has to go to work everyday. I don't have mom and pops to give me money.
  2. Drag ported cylinders with Forged WSM pistons and 170 compression. Good luck trying to catch him.
  3. The best thing to do. Is port your cylinders. You wouldn't have to touch anything else. Until another banshee beats you. LoL.
  4. I would say everything aftermarket is better. I know lots of guys down here in Miami. That don't like Cool Heads and prefer Stock Heads. Milled and cut to your specification. Is the way to go.
  5. JB Weld will hold up just fine .
  6. That would be great but i have a stock crank .
  7. How much are you asking for them ?
  8. Can you give me more specs on your setup please . I was mainly looking for Stokers .
  9. I'm looking to buy Cylinders , Pistons & Head .
  10. $250 and I will throw in the shipping.
  11. I'm selling some Ported Banshee Cylinders . They need to be Bored they are at 64.75 . And there's a Tiny Hole in the intake . That can be welded or epoxied . I'm asking for $250 and you pay shipping .
  12. My Shee always smokes more on the Right Side when its Cold . After a couple of minutes when its warmed 150 and up . They start to smoke Evenly threw Both Pipes .
  13. milto29
    KLOTZ?
    Super TechniPlate® vs R 50® TechniPlate®
  14. BR9ES is the way to go .
  15. milto29
    KLOTZ?
    Whats a good OIL for 100LL AVGas ?
  16. Hello Guys I was wondering if you can help me out . I just Bored my Jugs to 66.25 with Wiseco Pistons . Pro Design Cool Head with 20cc Domes (165PSI) . +4 Timing with CPI Small Bore Pipes . Running on 100LL AVGas . No Air Box only PODS. Stock Crank , Stock Carbs and Stock Reeds . What would you guys recommend . I'm in Miami so its about 78 to 85 down here . Thanks
  17. Thank you for your reply . Ill pull the Head off this weekend and check . What Oil will mix up good with 100LL AVGas ? As for the Cylinders I'm looking around for some but that will be when these Fail . I know 2 Bikes down here in Miami ( Sleepers ) that are Bored to 68 with stock Cylinders and Drag Ported . With a stock Crank and they are a BEAST .
  18. Standard Bore Pro Design 20CC Domes on a set of 66.25 Jugs is that OK ? Or do I need Big Bore Domes ?
  19. Thanks. I think ill just do that. This is a fresh Top End. Ill have to look for set of stock cylinders then. She's got lots of low end power. I just want more speed.
  20. Thanks for all of your replies. I forgot to mention. I do have Pods and +4 on timing. As for the marine oil. I like the smell better then Klotz which I also have at home. I also have Hi Flow impeller and Trail Tech Vapor. For Speed , Temp and RPM.
  21. Thanks for all of your replies. I forgot to mention. I do have Pods and +4 on timing. As for the marine oil. I like the smell better then Klotz which I also have at home. I also have Hi Flow impeller and Trail Tech Vapor. For Speed , Temp and RPM.
  22. Any Suggestions will be greatly Appreciated. I have just ordered a 15Tooth Front Sprocket.
  23. The same thing happened to me and it was the Exhaust Port.
