milto29
Everything posted by milto29
  1. http://www.farmandsandtoys.com/partdetail.asp?partid=403 Sent from my HTC One using Tapatalk now Free
  2. Wrong. SERVAL WAMPUS. Is what I'm getting. Read the older post. Sent from my HTC One using Tapatalk now Free
  3. Lol. Thanks man. I will take that into consideration. Sent from my HTC One using Tapatalk now Free
  4. PMR in Miami had one and he said that he never had any problems. Sent from my HTC One using Tapatalk now Free
  5. Yeah I think I'll do that. I'll post my findings once I'm finished. Sent from my HTC One using Tapatalk now Free
  6. Did you read my 2nd post. It doesn't matter who makes it. I'm not getting them from Calvin. Sent from my HTC One using Tapatalk now Free
  7. I understand what your saying. I want this only for trail riding. Full stand up trail bike. Sent from my HTC One using Tapatalk now Free
  8. The only specific reason. Is the great price that I can get them for. The stealth look is a plus aswell. Sent from my HTC One using Tapatalk now Free
  9. Probably I would have to ask. I was just wondering with the lower port timing. It will be great for low end power. Sent from my HTC One using Tapatalk now Free
  10. I can get a great deal on them. Sent from my HTC One using Tapatalk now Free
  11. Something went wrong on the pc. Sent from my HTC One using Tapatalk now Free
  12. Hey guys I’m building another Trail Bike. But I still don’t know which setup to go with. I’m going Serval for sure. I’m just not sure which one. Its either 421 Serval Wampus or 472 Super Serval Wampus ? Sent from my HTC One using Tapatalk now Free
  13. Hey guys I’m building another Trail Bike. But I still don’t know which setup to go with. I’m going Serval for sure. I’m just not sure which one. Its either 421 Serval Wampus or 472 Super Serval Wampus ?
  14. Who did the Port Work & how much for the Tranny ?
  15. Send me pics of the Cylinders,Crank and Case. 305-796-9269
  16. Yes I did but it's still coming up. Sent from my HTC One using Tapatalk 4
  17. I don't know about culprit. Fouled plugs that day only. Sent from my HTC One using Tapatalk 4
  18. It was very HOT that day and I was running on 340 mains I also had to change plugs because it was fouling them. I had on BR9ES and swapped it to B8ES. It did run alot better. I didnt try to take it hole after swap.
  19. Thanks will do. All of the Jets on the carb are new. I just finished taking apart my motor and everything looks perfect except the piston crown. It looks way to rich. Besides that everything else looks perfect Cylinders, Reeds and Head. I did notice inside the right CPI was my o-ring in pieces. I don’t know if that has anything to do. I took everything apart since I am doing my transmission work. Thanks for your feedback.
  20. Would bad or clogged up carbs do that ? I was also having problems shifting gears as well. It wouldn't go into 3rd and 6th at high RPM. Also when I would power shift 2nd to 3rd it would go into neutral. I don't know if that would be a contributing factor. I have a fairly new transmission assembly that I was going to put in. But I don't know if that would effect the power loss out of the hole. Sent from my HTC One using Tapatalk 4
  21. I was going to check that today.
  22. They are brand new. Yes they are clean.
  23. Hey guys When I went riding this weekend. I noticed that my Banshee was dying when I would take it out the hole. (Example) I have it WOT and then I pop the clutch , it wont stay on power. It cycles threw the gears normal and I still have my Top End power its just out of the hole. What do you guys think it might be ? I pulled my Reeds off and they look good. I pulled my Plugs off and they look good. I have a fairly new Clutch which I think it wouldn't matter. This just started to on Sunday. When I used to take it out of the Hole she will never loose power at all.
  24. What do you have ? Yes they are just a bit.
  25. What do you guys think is the Best Clutch out in the market right now? I'm in the process of buying a new Clutch but it’s hard to choose from all of the ones out right now. For example Barnett, F.A.S.T, EBC, Hinson & DP.
