3s1k
Everything posted by 3s1k
From what I found from searching is guys use 2 links for quick gear ratio changes. Like changing sprockets I guess. Instead of needing more than one chain.
I bought the swingarm and chain of craiglist for $110 so can return the chain. I looked at the chain and it looks barely used so I don't want to spend money if I don't have too. I read of people using 2 master links here on BHQ is that advisable? I'll probably switch back to the stock gearing. I rode it ibce since I got it and it seemed to top out pretty quick.
I got my banshee used and it already had a 47t rear sprocket. Not sure if that's for lower top speed or what. I also found a 41t sprocket which I think is the stock on. Anyways what is better for all around riding? I bougt a +4 swingarm and it came with with a chain. I installed it and the chain is to short like 8-9 links and I mocked up the stock sprocket and its still short like 5 links. I even pushed the axle all the way in on the chain tensioner. Do you guys know what size chain I need or do I just count the links an add extra?
Pm me a price on the a arms.
Looking for some extended aftermarket A-arms for my banshee. Let me know what brand and how much shipped. If you pix that would be great. Thanks
$75 shipped for your set of black a-arms
Got upper right side a arm?
Still have a set available?
How hot do you think the stinger gets on the pipe like where the rubber clamp goes?
Is that outside or inside diameter?
just some riding gear lying around, not uesd any more
3s1k replied to badbanshee509's topic in For Sale - Parts & Accessories
Did you ever get your money? I want to buy something but want to make sure this is resolved before I risk my money? -
What year brakes are compatible. I don't want to get the wrong ones.
Just curious on why the stock a-arms suck? I got a free set of stock yfz450 arms I'm going use since I'm broke.
Is it possible he put the upper a-arms on the wrong sides? I.E left upper on the right side. It looks like if it was reversed the shock would be centered.
While searching around some more i found out with little modifications you can put YFZ450 A-Arms on a banshee. The uppers are straight bolt on but the lowers need a little work. According to the "How-To" these are equal to a +2 +1 http://bansheehq.com/forums/index.php?showtopic=69059
Let me know what you got? Im looking for +3+1 or +2+1's preferably with ball joints.
I thought of compiling a list of parts that are compatible with the Banshee that come from other ATV's. Maybe make it an ongoing list as people find more compatible parts. Also list what the benefits are and what is needed to be done. I'll start from some stuff I found just from researching. YFZ450 front shocks. I read these are a good upgrade over the stock Banshee shocks. It requires a little grinding on the top and bottom shock mounting locations. Honda 300EX front shocks - If your looking to lower your front end for drag or MX racing. It will lower the front 2-3". Not recommended for jumping or rough trail riding. Spacers might be needed for the bushings as the 300ex bushings are thinner. R6 rear shock - Will also lower the rear end of the bike. The banshee bolt won't fit the R6 bushings though. You can have a new bushing made or possibly use a smaller bolt but the latter is not recommended though. If you guys have anything to add please do or correct anything I posted. I haven't tried any of these myself just stuff I have found from researching after I got my Banshee a month ago.
93 is like race gas up here in Alaska. Your lucky to get that at the pump. Highest we get is 90. About 5 years ago they removed 91 at the pump from all the stations.
I'm kinda new but what kind of transmission oil are you using? Is your clutch slipping?
I thought you don't need studs with cool head kits?
I know prices may vary, but what are you guys paying to get your frames PC'd?
Sounds like they need a rebuild to be safe. I was looking at the PeP and one of the seals around the shaft looks a little mangled. What are these shocks worth? Is it worth just buying another set of shocks or rebuilding these?
They come right back up when I push them down, is there anything else to look for? I plan on sending them to Matt but I want to make sure they need rebuilding before I spend the money as 1 of the banshee's needs some work/money to get running.
I bought 2 banshees for $2000, one works and one doesn't. Anyways. In the box of parts if found a set of Piggyback PEP shocks, they look really dirty. I pushed down on them and they were really hard came back up quickly. On the non running banshee there was a set of Works non piggy's. One of the Rods look a little bent. Anyways my question is how do I know it they need rebuilding or just a little cleaning? Is it possible to bend the rod back?
