2 Stroke Man
Everything posted by 2 Stroke Man
  1. Great seller! Will definatly buy from him again
  2. Update, Still need -stator and timing plate -throttle cable with carb caps -upper a arms -upper a arm sleeves and bolts -pistons Thanks
  3. Update, Still need -stator and timing plate -throttle cable with carb caps -upper a arms -upper a arm sleeves and bolts -pistons
  4. Hey guys! I'm looking for a thumb throttle kit (TORS eliminator) for stock carbs Throttle cable and carb caps Pm or text 4437992271 Thanks Chris
  5. Hey guys at banshee hq! I just need an upper left a arm Pm or text 443-799-2271 Thanks again !
  6. What's up guys at banshee hq! Let me know, I just need an OEM or OEM fit Airbox Pm me or text 4437992271 Thanks Chris
  7. It's alittle too much for me, thanks though
  8. Hey guys ! I need a few parts -Upper left a arm with bolts if possible -Stator and timing plate -Clutch cover -Pistons/crank -Flywheel puller -Pressure plate Let me know what you have Thanks guys You can text 443-799-2271
  9. Yeah I already have a set of FMF pipes, ill just be doing mostly trails/fields
  10. What's up guys at BansheeHQ! I have the stock carbs missing the tors and I know I can buy the eliminator kit but don't want to deal with jetting and syncing the carbs. I hear the 2in1 carb and 2in1 exhausts increase bottom end power. Just let me know what you have. You can text 443-799-2271 Thanks Chris
  11. Text me 443-799-2271 Thanks
  12. Still have the motor mounts/tie rods?
  13. Hey guys! I'm looking for any miscellaneous bolts for a banshee. I'm missing a good amount of bolts, if anyone has any bolts laying around please let me know :)Thanks
  14. Thank you I forgot about that Lol can't believe I forgot about that I'll keep you guys in touch about the project
  15. Hey guys at BansheeHQ! I recently bought a 1999 Banshee, basically rolling chassis.( only need upper A arm, and a tie rod) Also came with most of the motor parts( pretty sure just missing clutch plates, inner hub, fly wheel, stator, and pistons) Now for the fun part. There are a good amount of electrical wires and looks very confusing.(I'm a dirt bike guy btw) I just don't know where to start and when I get to the electronics, how would I test that they are working properly. If anyone has any suggestions, that would be great
