turbosrt4
Everything posted by turbosrt4
  1. just installed this kit what all shocks will work with them ?yfz 450r? kfx ?
  2. well i guess its just the nature of the beast>service manuel even says to start a warm motor to open throttle
  3. ordered a carb too' to check floats would that cause starting issues if there wrong like flooding?
  4. got a new cdi still hard to start when warm acts flooded if i crack the throttle starts good ,i just dont get it
  5. Ok checked caps 4.8 and the other 5.1
  6. Get them from fast ?and i check the boots i can never get a solid steady reading at all two sets of caps all the same
  7. how do i check the caps
  8. so 6.5 is good
  9. Ok ill try it
  10. i have a ohm meter how do i check them
  11. No i think i just need to get a dynatec ignition system
  12. Elevation 850 pipes rockets two 421 cheeta built by cascade 180 psi vforce 4 reeds plus 5 timing 20 cc domes 95 degrees
  13. no help tried two stators two coils and new wiring harness same old cdi
  14. Ok as of now my jetting is 155 main cel needle 3rd clip 52 pilots runs good but dont want to start after its warm and has been sitting for 5 minutes .unless i crack the throttle, ive trie 50 48 and 45 pilots no change
  15. still have not figured this out
  16. i was thinking casscade
  17. the slideswas not wrong but yea trying to get a info on thr two
  18. whos a good builder for this
  19. dalton ga and yes the washer is the i just took the carbs apart and checked everthing there clean
  20. id the crank is out of sync it will cause a miss also have you ever seen one do that??
