kabner
Everything posted by kabner
  1. Thanks guys. I figured that was the issue. I can not remember what the size pilot was but I will have it and the 280 main back in by this weekend.
  2. I am sure this has been covered many times but it has been hard to find a specific answer so I figured I would post my own issue. I recently purchased a 98 Banshee that is basically stock outside of Fatty Gold Series pipes. The machine had sat for a while so I rebuilt the carbs for general upkeep purposes and I used a stock rebuild kit on both carbs. Following the rebuild the machine will not idle without the choke on and instantly dies when I turn the choke off. I did notice when I rebuilt the carbs that the main jet was a 280 and which I replaced with a stock 200 jet. Could this change be the reason the machine will not idle without the choke since it has aftermarket pipes? Side note: I adjusted the idle to a point it idled quite high with the choke on but it still died when I turned the choke off. I am in fear I could seize the piston if I am not careful. Also, I disconnected the TORS system due a malfunction that caused the motor to bog at half throttle. Any advice would be greatly appreciated.
