Cpt Obvious
Everything posted by Cpt Obvious
  1. I use GBC sand sharks. They grip, are light and show little wear. And you can find the cheap
  2. What are your opinions about using iridium spark plugs?
  3. I've been trying the samething. Your headlights now only work on high beam and not low is because your only plugged into the high beam wire. If your headlights are more then 35 watts they will draw more power then your bike can put out, which will make your brake light dim.
  4. how many watts does a stock stator put out? I'm trying to put high output lights on and wondered how high I can go without putting on a different stator. thanks
  5. I just got my first banshee about a month ago. Its a '96 and I'm looking to get it dune ready. When I got it, it was fully stock. So far I've put fattys and 30mm carbs with a K&N in the stock air box. I'm wondering else I can do to it that will get the most juice with out major engine work??? also what is the suggested jet size and what kind of paddles do you recommend? Thanks
