johnzboy
Everything posted by johnzboy
  1. I'm getting the pipe set not the kit. I've have 35 pwk and pods Sent from my SGH-M919 using Tapatalk
  2. I am ordering t5 pipe set from rockymountain. What else do I need to install these? I know front hangers but what else? Oring, spings, pipe seals, rear mount? Thanks Sent from my SGH-M919 using Tapatalk
  3. Bump for a great seller! Carbs look great, kept me informed on shipping! Thanks! Sent from my SGH-M919 using Tapatalk
  4. For those of you who had questions about this. This is a nice product from Cascade! I ended up cutting a 3" hole in the clutch cover. This will only let you access adjustment on the pancake bearing. here is what it all looks like!
  5. Its on cascades website. Its under cascade banshee parts. It called a clutch covet insert. It allows you to adjust pancake bearing and thats it. Just have to cut your stock cover. They said they were discontinuing them soon.... Sent from my SGH-M919 using Tapatalk
  6. Just ordered there insert with the orings. I called them and asked how big of hole can I cut in the clutch cover for adjustments. They did not know...... can someone tell me. I can go ahead and cut the hole and finish the motor this weekend and install in the frame. Thanks Sent from my SGH-M919 using Tapatalk
  7. thanks guys! it was a good feeling about the 3 min mark!
  8. My first Banshee build! Passed the leak down test! 6 psi for almost an hour now. so close to going back in the frame. I cant wait! 4mil vito's crank, .020 over HJR dune port.
  9. Great seller! Great price on the stator cover! Stayed in contact about the shipping! Thanks! Sent from my SGH-M919 using Tapatalk
  10. Bump for great seller! Stayed in contact with me on shipping! Thanks! Sent from my SGH-M919 using Tapatalk
  11. Ill snap some pics in the morning Sent from my SGH-M919 using Tapatalk
  12. I have a stock set still atached to spindles. Make me an offer Sent from my SGH-M919 using Tapatalk
  13. Souththirty. Sent you a txt. No reply
  14. Looking for an aluminum stator cover. Shipped to 27406. Thanks
  15. my project is starting to come together! Kevin has my cylinders, cant wait to get them back! Here is what im going with: 4 mil long rod Herr dune port 28 pwk carbs (open to sugestions) pump gas ( what ever domes kevin tells me to buy) chariot reeds Im 165 lbs with no gear on (evey builder i contacted asked me this) I will be using this from 700 to 2000 feet above sea level Anything from messing on a mx track, fast trails, and some tight sections in the mountains. What exhaust would best suit my motor and me. Ill ask kevin also, but also like to here what everyones opinion is. thanks guys.
  16. Kevin has my cylinders now. He is doing a 4 mil port on a set of dune ported cylinders. I was going to go with his crank, but I have been readin mixed reviews. Some are happy some say hot rods.... I don't know. Kevin's, hot rods, hot rods extra weld, different bearing...... Any help would be apeciated!
  17. johnzboy
    Single a arms
    Do you mean j arms? If so I have a sock set upper and lower with spindles and calipers.
  18. i have a set of spindles for older brakes
  19. Sweet! Thanks guys! I work in a hot rod shop and we own the machine shop next door. So I will disassemble and modify as needed.
  20. NICE! frest powdered hubs and new bearings installed.... Back to the drawing board.... Thanks
  21. after looking on ebay it looks like the newer years hubs have a flush allen head bolt on the rotors.... does some one have any info on this? does it require newer rotors? newer hubs?
  22. I cleaned up a set of yfz 450 calipers and i am trying to install..... The shee was an 87. It is now an a arm frame and also installed a arm spindles. The prob I am having is that when I try to start the bolts in the caliper bracket, the bracket wedges into the allen bolts holding the rotor to the hub. What am I missing? thanks guys
  23. I need to by a set of cylinders. $150-250 Talked to site sponsors about porting. $300 Bore, hone and pistons. $300 I found some 400cc cheetah cub cylinders with pistons and gaskets for $1000 This is a play/trail bike. These two options are close in price. Which is a better platform for what I'm wanting?I have no pipes, reeds, carbs yet so I can match what I get.
