when i used to drag race my rotax 670. i ran 110LL mixed with 94 pump gas with no problems at all. up here av gas is way cheaper than c16. and at the end of the season if i had fuel left everything got av gas lol, lawn mover, quad,, ect.....
1) What type of aftermarket exhaust do you have? DG
2) What type of airfilter do you have? K&N
3) Are you running? air box with no lid
4) What is your elevation? 500 - 800 meters
5) What size pilot jets are you using? 25
6) What size main jets are you using? 310
7) What temperature is your Banshee jetted for? 40-50 degrees
8) Do you have a port job? aggressive trail port
9) bore/stroke ? stock stroke 69mm big bore
10) What kind of carbs? mik
11) What size carbs? 34mm
12) Do you have a coolhead? not yet
13) What brand is your coolhead? N/A
14) What size domes are you using? ?
15) What type of fuel are you using) 91 pump
16) What gas/oil ratio you use? 32:1
17) What type of premix you use? amsoil dominator
anyone ever ran these? found a good deal on a set and wondering if i should grab em. i do mostly trail and gravel pit riding
http://www.intercotire.com/tires.php?id=31&g=3
got some more info yesterday. apparently its not stroked, it has the hotrod oem crank in it. with these jugs on it
http://bansheehq.com/forums/index.php?showtopic=148026&st=0&p=1277532&fromsearch=1entry1277532
hey just curious , i picked up a banshee with a 403 big bore and it has 69mm pistons in it with 21207 part number on top. is this the same as yours? if so what brand are they?
well i took the head off because the head gasket was leaking and presureizing the coolant. it has a solid copper head gasket with 69mm pistons. it is the stock 54mm stroke. i see it has 2 base gaskets under the jugs, and in the box of stuff that came with the bike there is a aluminum spacer. should that spacer be in there?
hey guys, just picked up my first banshee and i am amazed with the power. the guy i got it from says that it has a 403 big bore/ stroker. the jugs have all the factory casting numbers on it, but it looks like it has C T engraved in the side of the jugs undere the black powder coat. is there any way i can identify this with out tearing the engine down?
