strokersteve
    87 banshee, 403 stroker
strokersteve's Achievements
  1. what do the bushings at the frame end of the arms look like?
  2. when i used to drag race my rotax 670. i ran 110LL mixed with 94 pump gas with no problems at all. up here av gas is way cheaper than c16. and at the end of the season if i had fuel left everything got av gas lol, lawn mover, quad,, ect.....
  3. sorry to hijack but im still a newbie. what is a lock up or sling shot clutch?
  4. 1) What type of aftermarket exhaust do you have? DG 2) What type of airfilter do you have? K&N 3) Are you running? air box with no lid 4) What is your elevation? 500 - 800 meters 5) What size pilot jets are you using? 25 6) What size main jets are you using? 310 7) What temperature is your Banshee jetted for? 40-50 degrees 8) Do you have a port job? aggressive trail port 9) bore/stroke ? stock stroke 69mm big bore 10) What kind of carbs? mik 11) What size carbs? 34mm 12) Do you have a coolhead? not yet 13) What brand is your coolhead? N/A 14) What size domes are you using? ? 15) What type of fuel are you using) 91 pump 16) What gas/oil ratio you use? 32:1 17) What type of premix you use? amsoil dominator
  5. anyone ever ran these? found a good deal on a set and wondering if i should grab em. i do mostly trail and gravel pit riding http://www.intercotire.com/tires.php?id=31&g=3
  6. Welcome Ben, these guys will take care of anything you need to know
  7. its a hr204 crank and ck121 rods
  8. got some more info yesterday. apparently its not stroked, it has the hotrod oem crank in it. with these jugs on it http://bansheehq.com/forums/index.php?showtopic=148026&st=0&p=1277532&fromsearch=1entry1277532
  9. hey just curious , i picked up a banshee with a 403 big bore and it has 69mm pistons in it with 21207 part number on top. is this the same as yours? if so what brand are they?
  10. anyone seen a head gasket like that?
  11. any idea what i should torque my head to with the copper gasket? and should i put any sealer on the copper first? or install it dry?
  12. can you please post a pic of your a-arm?
  13. I have a 88 and was wondering if anyone has ever fitted upper A-arms off a newer bike on to a single arm setup?
  14. my head gasket is .80mm thick and the piston sticks out about that much
  15. well i used my digital calipers and measured 54 mm from top of jug to edge of piston while at bdc
