sylverbullet57
Everything posted by sylverbullet57
  1. Looking for radiator hoses , front bumper, and rear bumper, dowel pin for cluth cover to case,rear shockspacers thanks
  2. yeah doing what you stated did help some .but i thought it had to shift without doing that?yes purchased a new one and got it adjusted correctly ,ialso ordered the spring that rides on that bolt to see if it helps
  3. i ran into a little issue and im sure cn help me out i would really appreciate it.my reason for tearing down my engine is because i had a small leak on my clutch cover ,when i drained the oil i seen metal shavings so i tore the engine down ,it ran and idled great before tearing it down however when i went to put the cases back i was doing what the clymer manual said about checking the trans for shifting and its binding up on me .the adjustment bolt is new and adjusted correctly,it shifted fine before tearing it down .everything was thoroughly cleaned with simple green ,clean water ,carb spray then compressed air the lubed up and installed .will the shifting issue go away once its all together and running?all replies appreciated thank.
  4. i drained the oil out of the engine and noticed a bunch of metal in oil .so i pulled the clutch cover and the inside of the cover showed signs of grinding im pretty sure this where the shavings came from .can anyone tell me whats going on here?i also took a couple more pictures to see if you guys can let me know if the top end looks good ,this engine ran really good before i tore the banshee down to the frame to powder coat and add some goodies to it .any and all replies are always appreciated.thanks mates
  5. pipes sold to johnnycash
  6. I have t5s for sale with stingers and silencers they have some rust that can be cleaned up pretty good or u can just paint them.I've never sold anything here but I've bought things from members here I'll post pictures later or you can text me and I'll send pictures 3234235066 Ricky .150 plus shipping
  7. What brand fat bars?
  8. I have a arms front'shocks and an axle .these came off of my 2001 .ill take 90 plus shipping.everything works .ill add pictures when I get home or I Can text them 3234235066
  9. Are the plastics still available?
  10. that would be nice ,im in downey california so im about hour and 45 minutes away .that pricing is not bad at all .thanx for the response thomas
  11. did he completely reassemble your engine? Thats what I want I dont wanna waste any money or time on this build.thanx for the reply
  12. sup guys i just got my first banshee,well i actually got it in nov 2011 ,2001 stock except for the t5 exhaust.i have it all apart now ,gonna powder coat it ,i already picked up some works triple rate w resi shocks off of craigslist ,i want to have them rebuilt,and coated by matt from socal suspensions .does anyone have picture of what i should grind off before having it coated? also whats the price range for having my stock engine rebuilt by hjr?ill have pictures up later thanks guys.....
  13. Congratulations on the new baby girl.
