Just bought a 1995 Banshee from my brother in law for $500. Compression in both cylinders is 120, has a full FMF gold series exhaust, Mikuni carbs, NGK plug wires,and some kind of aftermarket reeds. He was told when he bought it that it was bored out .40 over but doesn't know for sure. The ignition is disconnected and there is a red and brown wire nutted together and a black and black/white wire nutted together, does this seem right? Also, I had it started in the summer, but wasn't able to get it started now, last time it was ran was when i started it but the throttle stuck. Any suggestions on tuning it to get it to run smoothly. What is good to lube the throttle cable to prevent sticking and I took the carbs off today to clean them but didn't take them apart yet, what size jets should I have in there? Any tips or suggestions I greatly appreciate. Thanks !
Also I plan on changing out all the fluids what should I use for gear oil and premix as well as the ratio to mix at and brake fluid? Also is engine ice coolant safe to run too.
