4mildkue
Everything posted by 4mildkue
  1. 4mildkue
    Fuel pump
    Well I might have to because I run 1/8 and I don't want to lean it out
  2. 4mildkue
    Fuel pump
    I wanna keep it simple as I can but if the pump is not needed then Im just going to go with the big bowls and the pingle again
  3. 4mildkue
    Fuel pump
    41 on a 10mil dm
  4. 4mildkue
    Fuel pump
    Damn that sounds complicated
  5. 4mildkue
    Fuel pump
    Im building another bike on alky I already have one that I'm running a dual pingle and bigger bowls...so this time I want to run a fuel pump its the manual one not electric..does it hook up were the pingle was?? If not where, I need all the help I can get
  6. Yep sure did
  7. Ok thanks man
  8. Yes I'm running them drag and do they hook pretty hard??
  9. Just bought some brand new american racers do anybody know how many pounds of air to run in them
  10. Ok thanks guys I just order from m/m very good guy and was very helpful
  11. That's man and who has the best bowls I was thinking about ordering some from rdz have anybody used these pwks carbs
  12. Do you know who cut the trans and is it new
  13. So it would be best just to buy the bigger bowls and run those with my dual pingle
  14. I ran 6.93 at 93mph in the 1/8 on my 4mil stock cylinder on race gas and with the shifting problem...so with alky and a cut trans do anybody have ideas on how fast my bike will pick up
  15. Ok I've heard that to but wasn't sure how that worked out
  16. Ok thanks man I'll guess ill just find one on here and buy it
  17. Oh ok rdz told that I was making to much hp to have a stock tranny but I was wondering if there were ways around it but I was kinda of hesitant about the override because I heard they will tear up
  18. So what the best trans for the 1/8
  19. I'm having problems shifting from 1st to 2nd on my drag ported 4mil...will the shift star work or should I just get a cut trans if so witch is the best for the 1/8 asphalt
  20. What about Castro 927?? Ive heard it was pretty good
  21. Ok thanks guys for all the advice that really helped out a lot
  22. So with my dual pingle and bigger bowls And purge it if I'm not going to ride in a couple of days the setup will work fine?? And is it true I will gain 8-12 more hp??
  23. I'm about to switch from race gas to alky my motor is a 4mil fully drag ported with case porting noss machine head with 17cc domes boysen reeds with billet intake and 39mm pj carbs with rdz outta frames light weigh fly wheel timing set at 5 degrees and with a pingle..I will be switching to 38 pj alky carbs my question is will my domes work with alky...will the pingle and some bigger bowls workout...or should I run a fuel pump and what degrees timing I need to run and how do I not lean it out..
