Tony M
Everything posted by Tony M
  1. Take a look here at my craigslist ad. If i can sell soon i can get an awesome deal on my next ride! http://minneapolis.craigslist.org/hnp/rvs/3547856679.html Call or text 763-482-2230 Thanks, Tony
  2. Well this was dumb and had me puzzled for a while. I was riding saturday on the snow and ice, snow then got up into the radator and melted then water dripped on all my electrical connections and froze. The water build up was key ignition conection causing a bad connection making poor and here and there spark. I made a pig tail connection tomorrow ill soilder for more permanent conection.
  3. Just figured id add that the head lights work to eliminate some things being wrong. So the spark chooses when it wants to work. It quits then works again for a short time. Do ignition coil packs oftenly go bad?
  4. Hey guys I was riding last saturday and my shee started to die like it was running out of gas( bwaaa... bwaaa...bwaao.o..o.....) Sounded just like that lol. I kicked alittle bit and it fired up then died the same way again. Eventually it wouldnt start. At first i thought it was a fuel issue, either too much or not enough. Plugs were soaked with fuel but that was most likly cause of all the kicking over. Last night i replaced the plugs, checked compression (150psi a hole) and turned off gas and kicked it over alot of times to get gas out if there was any AND i checked spark, and it was there at the time. Then i fired right up!! I let it warm up a bit and decided to take it for a quick spin, i hoped on kicked it in first and moved 2 feet then it died again... would not fire again. Then i just put it away for the night upset. Tonight i checked the plugs again and looked over the carbs then checked the spark and i only saw one weak spark and couldnt get it to spark again. The headlights still work. I dont know where to start, what could be wrong and what should i check/replace. Thanks, Tony
  5. Ok guys you have helped me out so far but now that i have everything installed im having problems running. I have 310 mains and 25 or 26 pilots and the needle is set on the 2nd up clip and the air to fuel mixture screw right now is 1 1/2 turns out The banshee will run but eventually it will idle down and die and bliping the throttle will sometimes make it worse and it will die quicker. When driving it will do the same thing it will be going fine and then it will just seem like it runs out of gas. Next thing is that from idle to low mid range its really boggy and takes alitlle bit to get going/moving and sometimes it wont move at all unless you rev it up and then engage the clutch. What should i do next
  6. Thanks man! I just wanted someone to confirm my guess around 310 was close
  7. Well here in minnesota its gonna be cold till next may... And well the shee is running odd. Now the warmest of days are gonna be no warmer than 50 degrees. I need alittle help picking out new jets. Last weekend it started popping and hesitating in mid range, I took it out for a quick 5 min run once it was warmed up. The banshee has the following done to it High comp domes (150psi) Open air box with filter Toomy T6 high Rev pipes Currently the main jet is 280 and i dont know what the pilot Where is a good place to start here for 40 degree weather or so, 310? and do i change the pilot?
  8. Bump Also if someone has a rear skid plate forsale
  9. Off topic here, but how do you like those ambush tires? Do they get enough grip? Im thinking on getting a set
  10. I just bought a timing plate and flywheel puller and 15t front sprocket And the bike already has PT full mid pipes
  11. aftermarket timing plate, and i know where to get a flywheel puller but i just thought if someone had both and was willing to sell
  12. Also now looking for a timing plate and flywheel puller
  13. I bought nerf and set of rims and tires I still would like rear hole shot/ razrs or razrs 2. Just 9 inch tires or tires and rims I also still need an exhaust coupler and a front bumper still
  14. Great seller here!!! Nerf bars are awesome, good comunication and super fast shipping!!!
  15. People have been PM'ed
  16. I picked up a banshee this last weekend and today i was doing a tune up plugs, coolent, transmission... And i dont know if i did this or the previous owner did but the bottom thread of the drain plug in the engine block is stripped and i cant get a good start in the block. The theads on the plug is fine but i just cant get a good start with out it tightening up... Any suggestions, i dont know what to do so i dont screw it up.
  17. Hey Guys! Just picked up a 2001 Blue Banshee last weekend that needs alittle here alittle there. First off, what i really need is some rims and tire. I would like to find hole shots or something And exhaust couplers, one is ripped thru and the other side isnt looking so good. Also i dont like the front bumper, would like to find a aftermarket Last i would like to find nerf bar set Thank you guys let me know what you have PM me, post here or Text me 763-482-2230 Thanks, Tony
