lenrob
Everything posted by lenrob
  1. You should try closing your throttle more by the way of idle screw and lengthing your throttle cable. If your throttle blades are open somewhat on your idle setting it over rides your choke. Just give it a try
  2. It looks perfect to me, light brown ring and not black. I would say you are spot on.
  3. IMO I would start by draining all the fuel mix out of the tank completely, take the tank off and make sure no debris is in there also, pull both plugs and take a compression check, take the carbs off and pull bowls off them checking the floats and needles and seats, and jetting. Then pull the exhaust from the heads check for carbon build up and fix any exhaust leaks you have all the way back, and get your silencer repacked.
  4. Do you still have the lsr axle and hubs if so how much
  5. How much for the +3 a arms and +4 axle
