Sorry guys, it took a little longer for me to get into the bike then i thought.
Here is what i found out
Couldnt get the flywheel off so im ordering a puller. Turns out it has a timing plate set at +5.
pickup appears fine and flywheel key looks fine but ill learn more when i pull it.
One this i noticed is the plugs seem to be wet and reeds are almost dripping wet after running.
I also notice fuel is blowing back into the airbox. Backwards of the direction it should be going. My hunch is
that it is running really rich but when i lean the needles it gets worse. Can domeone point me in the right direction for main
jets? The one in it now have no markings. Im 2000ft about 80the degrees
Correct me if i am wrong, if i were having ignition problems wouldnt it affect operation at all rpms? Im only have problems when holding
throttle steady at half throttle
Thanks for your help
