Rory
Everything posted by Rory
  1. Rory
    A Arms
    Hello. any one out there with a set of a arms willing to ship to ireland?
  2. Float could be stuck.. you could try tapping the float bowl!
  3. Hello all My banshee leaking oil i found a crack on the casing just under shift shaft. i tried chemical mental and it worked fine for awhile but the crack got bigger.. any idea would it be something wrong inside the casing make the crack? and can it be welded? thanks in advance!
  4. Thanks lads will try that!!
  5. Hello all.. Im new enough to the banshee. just wanted to know what jetting ye think i should be using. my bike has fmf pipes with powercore 2 silencers carbon reeds KnN filter standard engine im preety much at sea level im from ireland.. bike is going well but wont really sit and idle keeps cutting out but will start again first kick! any idea what the problem is there? and also with my left carb the petrol flows out the over flow.. my mate said float stuck but when he blew into the carb through petrol inlet the floats workin but theres a slight bit of air getting threw.. could this be the problem for the overflow i was thinking maybe a seal gone? Thanks in advance for feedback!!
  6. Hello HQ!! newbie from ireland!
