snackpac
Everything posted by snackpac
  1. when you say pods what are you refering too
  2. dont know it was willed to me all i know is i put about 12hrs on it, what would be some recommendations, yamalube?
  3. ok thanks for the help will i need a new gasket if i remove the cover, if so will form-a-gasket work?
  4. Hello all long time lurker, long time quad rider,kinda new to shee's just statred putting this shee back together, but there seems to be a problem with the clutch, at first i thought the cable was just stretched out, so i bought a new one. Well now the new one came in the mail and I still have the same problem. The problem is that there is not much tension when you pull the clutch lever, it moves a little but not much kinda like the spring is worn out, is this possible? So when i am comeing to a stop after a ride and the clutch is fully pulled it pretty much dies as if the clutch is not fully engaged. So my question is does this spring wear out, the bike is a 96, if so is it hard to replace or do i have to remove the clutch cover and repair something from the inside. Thanks for any help you can give.
