Im in the process of rebuilding my banshee. I stripped her down to the frame and had it powdercoated.
So.. lets start with grounding. What all needs to be grounded to the frame? I know the wiring harness needs to be grounded at the rear of the frame. The ign coil has a ground wire but it has bare metal where the mounting bolts go through the coil so im wondering if the coil is also grounded to the frame through the bolts. Anything else im missing?
I have not removed any powdercoating at the ground connections so its just using the screw threads to ground. I checked the ground connections with my multimeter and everything checked out good but wondering if this will work or should i remove the powdercoating on the frame at the grounding points for a better connection?
Vent Hose.... I have most of the vent hose routing figured out but im wondering about the rear crankcase vent with the white fitting. Exactly how does that hose get routed up to the T connection? Does the white fitting in the crankcase point rearward, hose attaches to fitting and does a 180 deg turn over the rear engine mount bolt up to the T fitting? Or does it route a different way?
